FlightAware Discussions
Site local IP address change with new Pi
#21
My guess is you still have an intermittent connection to fix.
But that is more likely to be either a problem with the router or the cable or whatever, not really sure.
Regarding that intermittent connection could you post the output of this command:
sudo journalctl -u dhcpcd -en100
#22
I confirmed that I am also feeding 360Radar. Here’s the output you asked for:
Logs begin at Wed 2019-02-06 19:18:12 GMT, end at Wed 2019-02-06 20:04:57 GMT. –
Feb 06 19:18:14 raspberrypi systemd[1]: Starting dhcpcd on all interfaces…
Feb 06 19:18:14 raspberrypi dhcpcd[348]: dev: loaded udev
Feb 06 19:18:15 raspberrypi dhcpcd[348]: wlan0: starting wpa_supplicant
Feb 06 19:18:15 raspberrypi dhcpcd[348]: eth0: waiting for carrier
Feb 06 19:18:15 raspberrypi dhcpcd[348]: wlan0: waiting for carrier
Feb 06 19:18:15 raspberrypi dhcpcd[348]: wlan0: carrier acquired
Feb 06 19:18:15 raspberrypi dhcpcd[348]: DUID 00:01:00:01:23:7d:95:f4:b8:27:eb:ee:87:69
Feb 06 19:18:15 raspberrypi dhcpcd[348]: wlan0: IAID eb:ee:87:69
Feb 06 19:18:15 raspberrypi dhcpcd[348]: wlan0: adding address fe80::3fd3:e04d:b618:199a
Feb 06 19:18:15 raspberrypi dhcpcd[348]: wlan0: carrier lost
Feb 06 19:18:15 raspberrypi dhcpcd[348]: wlan0: deleting address fe80::3fd3:e04d:b618:199a
Feb 06 19:18:15 raspberrypi dhcpcd[348]: eth0: carrier acquired
Feb 06 19:18:15 raspberrypi dhcpcd[348]: eth0: IAID eb:bb:d2:3c
Feb 06 19:18:15 raspberrypi dhcpcd[348]: eth0: adding address fe80::cd0c:6630:7b83:36df
Feb 06 19:18:16 raspberrypi dhcpcd[348]: eth0: rebinding lease of 192.168.1.203
Feb 06 19:18:16 raspberrypi dhcpcd[348]: eth0: soliciting an IPv6 router
Feb 06 19:18:20 raspberrypi dhcpcd[348]: eth0: probing address 192.168.1.203/24
Feb 06 19:18:25 raspberrypi dhcpcd[348]: eth0: leased 192.168.1.203 for 172800 seconds
Feb 06 19:18:25 raspberrypi dhcpcd[348]: eth0: adding route to 192.168.1.0/24
Feb 06 19:18:25 raspberrypi dhcpcd[348]: eth0: adding default route via 192.168.1.1
Feb 06 19:18:25 raspberrypi systemd[1]: Started dhcpcd on all interfaces.
Feb 06 19:18:29 raspberrypi dhcpcd[528]: eth0: no IPv6 Routers availab
#23
Strange. Hmm maybe all is well now. Good luck! :wink:
#24
Sometimes the WiFi can be finicky, especially in crowded environments. In my house I can “see” approx 20 other routers in 2.4GHz band (even the electrical power meters have WiFi, to be read while driving a truck on the street) . And only another one in the 5GHz band.
That’s why I connected my Pi with ethernet cable now.
#25
SoNic, that’s why I didn’t (as far as I know) initiate wifi when setting up the new Pi. I have a similar number of routers locally.
#26
You are lucky. My WLC can see 120 odd 2.4Ghz WAPs and maybe a dozen on 5Ghz,
Thankfully some of them are just city buses that go past with onboard wifi.
#27
My experience with wifi is that using it is inviting trouble. I never use it on my Pi, except when testing a WiFi dongle.
I normally use wired network, which is headache free and performs very good. When at home, I even connect Laptop by a network wire to get good speed and smooth operation.
#28
And helps avoid any potential MITM problems.
