Signature verification error during apt update
I “upgraded” (in-place, not a re-image) from Bullseye to Trixie some months ago and have had no apparent issues until today.
When I run sudo apt update, get this error below:
Hit:5 ``https://www.flightaware.com/adsb/piaware/files/packages`` bookworm InRelease
Err:5 ``https://www.flightaware.com/adsb/piaware/files/packages`` bookworm InRelease
Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 4E49CAF6B9F2BF8FC240E4BAB931BB28DE85F0DD is not bound: No binding signature at time 2025-06-30T15:04:16Z because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
All packages are up to date.
Warning: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: ``https://www.flightaware.com/adsb/piaware/files/packages`` bookworm InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 4E49CAF6B9F2BF8FC240E4BAB931BB28DE85F0DD is not bound: No binding signature at time 2025-06-30T15:04:16Z because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
Warning: Failed to fetch ``https://flightaware.com/adsb/piaware/files/packages/dists/bookworm/InRelease`` Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 4E49CAF6B9F2BF8FC240E4BAB931BB28DE85F0DD is not bound: No binding signature at time 2025-06-30T15:04:16Z because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
Warning: Some index files failed to download. They have been ignored, or old ones used instead.
The flight aware sources file contains this
This file is automatically generated by the flightaware-apt-repository package
to point to the correct FlightAware repository for the currently installed Debian OS.
Any changes made to this file will be lost when flightaware-apt-repository is reconfigured.
To disable generation of this file:
purge the flightaware-apt-repository package; or
set ENABLED=no in /etc/default/flightaware-apt-repository; or
rename this file to /etc/apt/sources.list.d/flightaware-apt-repository.list.disabled
deb [ signed-by=/usr/share/keyrings/flightaware-archive-keyring.gpg ] https://flightaware.com/adsb/piaware/files/packages>
I assume my local flightaware-archive-keyring.gpg is perhaps out of date/incorrect.
Does anyone know how I can correct this error?
Thanks in advance!
Graeme
On Raspberry Pi OS Trixie
(OS written on a blank microSD card using RPi Imager)
FLIGHTAWARE
FLIGHTRADAR24
PIAWARE FROM MY PPA AT GITHUB
Click Here: Debian 13
Thanks for looking into this. I’ve since read that Debian 13 (Trixie) considers SHA1 insecure starting 1 Feb 2026. It would seem the repository .gpg key needs updating for Trixie!
The gpg key at my Github PPA meets this requirement, hence the apt can update it without any issue, and the 64-bit (arm64 & amd64) piaware, dump1090-fa, dump978-fa and piaware-web can be installed on 64-bit (arm64 & amd64) Trixie without any problem.
Flightradar24 has just now provided following method to download and install their updated gpg key on Trixie:
NOTE :
The 2nd command below is very long. Scroll right to see and copy it in full
sudo -s
wget -O- https://repo-feed.flightradar24.com/flightradar24.2026.pub | gpg --dearmor > /etc/apt/keyrings/flightradar24.gpg​
apt-get update​
FR24 New Key Data (for information only)
I wonder if FlightAware will consider doing the same for the bookworm repository. My Pi is still pointing to the Bookworm repository for updates despite being on Trixie and I appreciate I now have a non-standard setup…
I’ve now extended the SHA1 acceptance policy by another 6 months on my installation in case any updates/fixes get released in that that time
Thanks again for the feedback!
Compare the gpg Keys
(1) Flightaware CURRENT Key
(2) Flightradar24 OLD Key
(3) Flightradar24 NEW Key
Any updates on this? Having the same problem on bookworm!
