I recently configured dumphfdl (v1.7.0) on Debian 13 paired with my Icom IC-7200 via USB audio capture (arecord piped into dumphfdl).
It’s up and running nicely with a single-click script, monitoring frequencies like 10087 kHz. However, I’m still exploring the best practices for HFDL monitoring—such as optimal band selection throughout the day, decoding visualization/dashboards, and CAT integration.
Are there any fellow HFDL enthusiasts here using desktop transceivers or SDRs with dumphfdl? I’d love to hear about your favorite frequency setups, antennas, or tips for long-distance decoding!
To be honest, I was not familiar with VRS (Virtual Radar Server) until you mentioned it, but displaying the decoded HFDL data on a map sounds fantastic! Thanks for the tip and for the hfdl.observer link—that frequency map is super useful.
Success with DumpVDL2, but all the kudos go to my “good friend” Gemini. He/she wrote a Python Translator to convert the data from DumpVDL2 so that VRS could understand it.
Now I have ADS-B, VDL2, and HFDL displayed on VRS.
VRS has not been updated in a long time, I hope the developer is still active on it.
That’s hilarious—Gemini is indeed a great coding companion! Having ADS-B, VDL2, and HFDL all merged into a single VRS display sounds like the ultimate monitoring dashboard.
Thanks for sharing the story. I’m going to start setting up a map display on my side as well!
Since I’ve got dumphfdl running smoothly as a standalone setup on my Debian machine, I think I’ll start by trying out hfdl-web-observer first. It seems designed specifically for HFDL, letting me dive deep into ground station data, frequencies, and decoded messages all in one place.
Once I get that up and running, I might explore mapping integrations like VRS or tar1090 as well.
Thanks for the inspiration, and good luck with your multi-mode setup!
HFDL is very interesting. I’m receiving planes as far away as 7000km. I was suspicious about it thinking that it was just the signal from Riverhead-NY, the closest ground station.
I asked my “good friend” Gemini and he/she assured me that it was from the plane, that VRS discards the signal received from the ground station.
9,000 km is incredible! That’s the real magic of HF propagation. There’s nothing quite like catching a signal from an aircraft halfway across the world.
Thanks for the tip about DragonOS as well! A radio-focused Linux distribution sounds like a fantastic playground for SDR and telemetry tools. I’ll definitely check it out.
Meanwhile, I’m getting set up to run hfdl-web-observer on my Debian system!
There is a new VRS in the works called VRS X. It’s currently in closed beta with a release expected for December. Here is the info I found:
"The developer is planning the public release (v1.0.0) of VRS X for around Christmas 2026.
The application is moving through its final development milestones. You can track progress on the VRS X Roadmap, which relies on a sequential versioning timeline before launch:
Current Status (v0.8.3): Released on October 15, 2026, this build stabilized the software core, significantly improving heavy traffic handling in the PostgreSQL Traffic Recorder and optimizing MLAT data ingestion.
Next Milestone (v0.9.0): This upcoming version will introduce Flight Alerts, allowing users to build custom notification workflows and rule templates.
Public Release (v1.0.0): Scheduled to debut once v0.9.0 testing concludes and the closed beta community confirms that the self-hosted local server application is completely stable.
If the development of the flight alert engine stays on track, the unrestricted public download should open just before the end of the year. "
It’s great to hear that “VRS X” is actively being developed and that a public release is expected around Christmas this year. Modernizing the software core and adding PostgreSQL support sounds like a major step forward.
Thanks for sharing this road map—now we all have something extra to look forward to in December!
I tried to look for the repository for hfdl-web-observer, but I couldn’t find the correct active GitHub URL for a standalone installation on Debian.
If anyone happens to have a working GitHub link or can point me to a recommended lightweight Web UI/dashboard that works nicely with dumphfdl without Docker, I would really appreciate your guidance!
I was able to successfully install hfdlobserver on my Debian system without Docker. However, I am currently stuck on the configuration side.
Whenever hfdlobserver tries to switch and tune to an active frequency (e.g., 11184 kHz), it immediately encounters a (DirectReceiver) rtl-ch1 on [11184] encountered an error message and clears the frequency back to idle.
If anyone has a working settings.yaml configuration for a single RTL-SDR setup (or knows the trick to resolve this DirectReceiver tuning error), I would be very grateful for your advice!
Is VRS X project by Elon Musk?
Adding X to names is his speciality.
Even his son’s birth name is X Æ A-12 (later changed for California birth certificate rules to X Æ A-Xii
Sad news… Decided to withdraw from Airframes after less than a day
Hi everyone,
I have a sad announcement to share… After struggling for a while and finally getting everything configured and running smoothly, I am suddenly locked out and can no longer sign in.
I guess my setup and Airframes just weren’t meant to be, or we had a bad chemistry together! So, with a bit of regret, I’ve decided to pull the plug and withdraw my station after less than a single day of operation.
It was a fun, albeit short-lived, journey. Thank you all for the great community, and happy tracking to everyone!
I avoid being a “feeder” as much as possible, the only exception being FA, and that may change as well soon.
If creating an account is part of the setup, then it’s worse, and that is before factoring in TinyGS’s asinine procedure.
As for HFDL, install dumphfdl and VRS, both available for Linux.
Edit 1: If you want to feed a site, looks like OnAir has its own server. I did not try it, but looks like no account is needed, and the big plus is that it displays many services/modes.
This is the page:
Edit 2: This is the window one gets everytime OnAir is installed or updated:
Edit 3: I think, not sure, OnAir displays messages from HFDL ground stations as well as from planes. I prefer displaying messages received from planes only.
Thanks, @Dxista!
It’s comforting to know I’m not the only one who gets tangled up in account bureaucracy.
Maybe my station and I just need a quiet retirement for now.
Thanks for the tip on OnAir!
I don’t want anything to do with accounts, logins and passwords anymore if I can avoid it. As a matter of fact I’ve been deleting accounts for some time now. I have so many of them that all the info is in a pocket book, since I cannot remember them all.
