Hi,
I’ve got a QNAP TS-251+ NAS which has an Intel 4 core Celeron CPU with 8Gb of RAM, it supports Debian & Ubuntu through Containers and VM’s. I run PiAware on an RPi but the house gets in the way and as I can’t get the antenna above the roofline I’m looking at running a second unit on the other side of the house and thought I might try to get it running on the conveniently located NAS rather than a 2nd RPi. Problem is that I get errors during the build phase and not being a linux guru I was wondering if anyone on here has successfully managed to get an orange FA dongle running on a QNAP NAS.
Hi wiedehopf,
Very many thanks for the response, I’ve tried the instructions on your second thread but seem to fail during the build phase but it does look to be the best set of instructions.
I think I must be missing something in the QNAP build part of the operation, I’ve found in the past that QNAP have a habit of giving you basic generic installation instructions but fail to give you the specific what comes next instructions so you end up with a system with big holes in it.
I had hoped that maybe one of the members may have come up with something like “I’ve done that and you need to watch for …”
And are you running debian or Ubuntu, then it should be really straight forward.
You weren’t quite clear on what it was actually running, only what it supports.
Hi,
I’ve started from scratch and I have installed Ubuntu 18.04. Following the instructions you pointed me at, I kick off the command “sudo dpkg-buildpackage -b --no-sign” by a copy & paste and this is the result:
Hi wiedehopf,
Success!! Very many thanks for your help, it’s very much appreciated. I’ve got FA confirming that they are receiving data from me so I have just to configure location, height etc and when some aircraft get up in the air I might see them. I’ve just got to get VRS to work with the NAS as it’s using a virtual switch so I’ve got to try and work out the IP address and port number.
