Ride along in the cockpit of any plane your receiver sees: free 3D dashboard for PiAware, no Home Assistant needed
I’ve been building a dashboard for my PiAware near Halifax, NS. It started life as a Home Assistant card, and it now runs on its own, so it’s for any feeder, not just HA users. :tada:
adsb-monitor, the small companion service, now serves the whole dashboard itself. Install it on any always-on Linux box (the PiAware Pi itself works) and open http://<your-pi>:7100/ in any browser. There’s no Home Assistant, Docker or database, and it has no npm dependencies: just Node.js 22+ and pm2.
What you get in the browser:
  • Map: range rings, altitude-coloured trails pre-filled from SkyAware’s history, satellite or plain basemap, route lines, and filters by class (commercial, military with roundels, helicopters, private) and by airline
  • Aircraft list and flight page: route, progress and estimated arrival, photo, type and registration, altitude and speed charts
  • Coverage: a polar chart of your receiver’s range by altitude band, over a day, a week, 30 days or all time
  • Cockpit: sit in any aircraft your receiver is tracking, over Google’s photorealistic 3D world, with a green HUD (pitch ladder, flight path vector, speed and altitude tapes, and the selected altitude/heading and baro setting the aircraft broadcasts). It banks in turns, from the turn rate worked out from its changing track. On final it shows approach guidance with ILS-style glideslope and localizer diamonds, from your receiver’s data alone. (Needs a free Cesium ion token.)
  • SkyAware itself, embedded
Phone alerts without HA: emergency squawks, military aircraft and helicopters nearby, and every arrival at your airport (“on final RWY 32”, then “landed”, with a photo of the actual airframe). These go out through ntfy, a free push app (self-hostable), or through Home Assistant if you do use it, or both.
It works with PiAware / dump1090-fa (SkyAware) and readsb/tar1090. The FR24 Pi24 image’s older dump1090-mutability isn’t supported.
On a phone, use Add to Home screen and it opens full screen like an app. If you do run Home Assistant, the same card still installs from HACS as before.
:backhand_index_pointing_right: https://github.com/jchisholm59/adsb-monitor
And if you’re also into ships: there’s a sister project, ais-monitor, which does the same for marine traffic, using a free aisstream.io feed rather than a receiver of your own. It has a live harbour map, a bridge view from any ship over the 3D world, warship and cruise-ship arrival and departure alerts with photos, and 43 historic shipwrecks marked with their stories. It also runs standalone, on port 7110.
:backhand_index_pointing_right: https://github.com/jchisholm59/ais-monitor
Both are free and open source (MIT). Feedback and feature ideas are welcome.
I’ve installed it and got it up and running on a standalone setup (no HA).
Some remarks:
  • Include instruction on how to install Node.js 22 version or higher. That will enable the user to get there faster without having to find it out on the Nodejs page, they offer multiple options.
  • Installation has to be done with the sudo command when starting the install.sh script. stating without it will give an permissions issue on the installation op the NPM package.
  • Starting with sudo this installation will run correctly.
  • Skyaware adress has to include the http:// part prior to the IP adress of the receiver. With just the IP address the installation will not be able to reach Skyaware
Other then that is looks nice and I’m gonna play around with it for some days.
This is a really cool project for anyone who loves setting up their own local dashboards! For those who might find server configurations or installations a bit challenging, using built-in platforms like Flightradar24’s 3D view is also an easy and fun alternative to enjoy the flights. Thanks for sharing such a great tool for the community!
Initially Planefinder had their feeder for Windows only. In 2014 they introduced their first Linux (Raspbian) client which was Node.js base. Almost every one (including myself) complaind about a confusing and very lengthy procedure. They immediately abandoned Node.js and released a .deb package which got downloaded by wget command, and after download got installed by dpkg -i command.
Thanks!
I’ve updated the project to enable the same type of realistic rendering and orbit views as FR24’s 3D view offers.
Thanks Tom
I’ve updated the project to enable a realistic 3D orbital view if you’d like to do an upgrade and check it out.
Hi Jim,
You might want to include am upgrade feature in the install routine. Once installed it will produce a fatal error since the directory already exists.
afbeelding
So in order to upgrade you would have to de-install the current installation or allow to upgrade over the existing installation. Either one has to be described in on the GitHub page so users know what to do :melting_face:
Removal can be done easily with sudo rm -rf adsb-monitor then you can start over again and implement a new version.
Just a suggestion but it might improve the documentation and the user experience.
Updating an installed copy: don’t clone again (git refuses, since the folder exists) and don’t delete it (that throws away your settings and data/). Pull the new version in place and restart:
cd adsb-monitor && git pull && ./install.sh --yes
Hi Jim,
Add that to the description on the Github page and then the users know how to get updated (I just saw you did that).
I’m just trying to make your project a little better and easier to maintain for the average user :wink: Losing the data is not a big issue for me when the project is still in development
Done. Thanks Tom.
You should check out ais-monitor while you’re at it.
Cheers
Nope AIS is not my cup of tea, to far away from any reasonable body of water to get any kind of reception. (been there done that) :smiling_face_with_sunglasses:
Fair enough! Except it doesn’t need a local receiver. Stand on the bridge of any ship anywhere in the world and watch the scenery go by.
Thanks again for the feedback, Tom. Two of your first points are now fixed (adsb-monitor v1.12.1): the installer accepts the SkyAware address with or without http://, and it shouldn’t be run with sudo any more. It asks for your password itself if installing pm2 needs it, and stops with an explanation if you start it under sudo. To update: cd adsb-monitor && git pull && ./install.sh --yes
I get an error when arriving on step 3 using the command you gave in the above post;
afbeelding
Hey Jim,
I use adsb-monitor as my default desktop display of my receiver, I can see that it is single-site oriented but wouldn’t it be cool to monitor two or more sites aggregated onto one instance.
You should credit yourself in the UI (and the installed version).
Hi Proteans
Thanks, yes I’m working on that. Another site at my cottage (if it warms up lol)
Cheers
(post deleted by author)
