Reception dropped substantially
Morning everyone. For some reason the site at my house dropped in reports over the past few days. The northeast has been windy with arriving runways to the northeast but it shouldn’t have affected the receiver this much. I also noticed that the range ring distance has dropped as well. I had the UAT antenna installed over a week ago and the reports were great. Not sure what created the change. My receiver in Queens, NY is doing great with no changes.
Check if your connectors are still correctly closed, is the SDR seated correctly in the USB port? Check if there is no water in the connectors maybe?
In order to find the issue you will have to start eliminating the possible reasons of the drop. Start from the antenna and work your way to the SDR to make sure you check it all.
Thanks for the reply. I did not that the red LED on the pi was turning off when I moved the receiver. I did a full reboot and everything went back to normal. I did keep the pi in a different spot to monitor and it seems that the power supply cable isn’t the best and it was causing power instabilities. I ordered a new one that I should be getting today.
