Hi,
I have a Raspberry Pi2 already running Darkice and providing live ATC audio feeding. Now I’m trying to provide ADS-B feeding to FlightAware but the Dump1090 is clashing my Pi2.
I acquired the USB RTL-SDR & ADS-B Receiver and I followed all instructions of FlightAware to install the DUMP1090, but my Pi2 stops when I run any “dump1090” command.
I guess it’s related to some conflict between RASPBIAN OS + DARKICE + DUMP1090 but I’m unable to identify it.
If it’s completely wedging or rebooting when you start dump1090, you probably have power supply issues.
You might want to try running the rtlsdr dongle via a powered hub rather than direct off the Pi
I have a RADIOSHACK PRO528 scanner configured with the frequencies of the airport SBSV. It scans the frequencies in a loop and hold on an active frequency (conversations).
The scanner audio output (3,5mm) is connected to a USB audio input at Raspberry Pi2.
The LiveATC.net provided a tutorial to install and configure DARKICE application. They also sent the config file with the settings to feed this specific airport.
