Raspberry Pi Debian images - Latest Releases
First install missing package wget to enable following bash scripts to run
sudo apt-get install wget
Next make a folder named Flightaware to hold sorce codes and build packages
sudo mkdir Flightaware
Every time you want to run any of bash-scripts, first enter the directory Flightaware
cd Flightaware
Run following scripts from inside folder Flightaware:
piaware ver 5.0 - Built from source-code (master branch)
sudo bash -c "$(wget -O - https://raw.githubusercontent.com/abcd567a/piaware-ubuntu20-amd64/master/install-piaware.sh)"
dump1090-fa ver 6.0~dev - Built from source-code (development branch)
sudo bash -c "$(wget -O - https://raw.githubusercontent.com/abcd567a/piaware-ubuntu20-amd64/master/install-dump1090-fa.sh)"
After above bash script completes installation of dump1090-fa, run following command:
sudo wget -O /etc/udev/rules.d/rtl-sdr.rules "https://raw.githubusercontent.com/osmocom/rtl-sdr/f2a9a81/rtl-sdr.rules"
dump978-fa ver 5.0 - Built from source-code (master branch)
sudo bash -c "$(wget -O - https://raw.githubusercontent.com/abcd567a/piaware-ubuntu20-amd64/master/install-dump978-fa.sh)"
Assign Dongle Serials
sudo sed -i 's/^RECEIVER_SERIAL=.*/RECEIVER_SERIAL=00001090/' /etc/default/dump1090-fa
dump978-fa ver 5.0
sudo sed -i 's/driver=rtlsdr[^ ]* /driver=rtlsdr,serial=00000978 /' /etc/default/dump978-fa
piaware-web ver 5.0 - Built from source-code (master branch)
sudo bash -c "$(wget -O - https://raw.githubusercontent.com/abcd567a/piaware-ubuntu20-amd64/master/install-piaware-web.sh)"
Flightradar24 Feeder
sudo bash -c "$(wget -O - https://repo-feed.flightradar24.com/install_fr24_rpi.sh)"
Planefinder Feeder
wget  http://client.planefinder.net/pfclient_5.0.161_armhf.deb
sudo dpkg -i pfclient_5.0.161_armhf.deb
Radarbox24 Feeder
wget http://apt.rb24.com/inst_rbfeeder.sh
sudo sed -i 's/^VERS=`lsb_release -c.*/VERS=buster/' inst_rbfeeder.sh
sudo bash inst_rbfeeder.sh
ADDITIONAL INFO:
Whenever I issued a command starting with sudo, I got this message:
sudo: unable to resolve host rpi2-20210823: Name or service not known
In spite of the above comment, the sudo command did execute, but the comment was quiet annoying. I finally found solution as follows:
The file /etc/hostname has the host name rpi2-20210823
pi@rpi2-20210823:~$ cat /etc/hostname
rpi2-20210823
The file /etc/hosts does NOT have hostname rpi2-20210823
pi@rpi2-20210823:~$ cat /etc/hosts
127.0.0.1       localhost
::1             localhost ip6-localhost ip6-loopback
ff02::1         ip6-allnodes
ff02::2         ip6-allrouters
I added rpi2-20210823 in the following line
127.0.0.1 localhost
so it became:
127.0.0.1 localhost rpi2-20210823
Saved the file, and rebooted.
The annoying remark disappeared :smile:
