Thanks, the heatmaps are obvious, it’s the elevation plots I need to get my head around.
The heatmap will be useful as it’ll give me a good indication of which corner of the mast I want to mount the feeder when I lower it back down again as I’ll be blocking off a chunk of the sky. Comparing one after I lower it will be very interesting to see. I’m thinking I want the blocked area to be slightly east of NE if I can manage it.
Think of it as a panorama of the whole horizon - here’s a timelapse view of the same thing that lets you see how aircraft move from that viewpoint. It may or may not make it clearer. Aircraft are coloured by altitude in this: https://streamable.com/m6oav
Thanks. I’ll upload the script to do this at some point, but it’s a bit messy at the moment. It also will take an absolute age (many hours) to run on a pi, if it does at all. It takes long enough running it on my desktop machine which is a quad core i5.
This gives error (translated it says that the archive is not a known Debian archive format) for both packages:
> dpkg-deb: Fehler: »./gnuplot-nox_5.2.6+dfsg1-3_armhf.deb« ist kein Archiv im Debian-Format
> dpkg: Fehler beim Bearbeiten des Archivs ./gnuplot-nox_5.2.6+dfsg1-3_armhf.deb (--install):
> »dpkg-deb --control«-Unterprozess gab den Fehlerwert 2 zurück
> Fehler traten auf beim Bearbeiten von:
Any ideas?
Edit:
I think i found the error. The archive on Debian Repositories are lot larger, mine are only having 323 bytes on disk.
I haven’t changed the gain and in this situation, there’s no difference in cable length because it’s all self contained in the box you see.
If I decide that I’m going to fix a new FA aerial on top of my hexbeam then I will be introducing a run of coaxial cable, probably 4-5m long. Once it’s finalised then I’ll look at gain.
