hi,
anybody an idea where to change the piaware 3.7.1 feeder-id on a radarcape?
thanx
tom
hi,
thanx
tom
The Radarcape wiki suggests that the username must be the mac-address of the Radarcape:
https://wiki.jetvision.de/wiki/Radarcape:FlightAware_Feeding
But i donât know if this is current.
If you have console access i donât see why this would not work:
sudo piaware-config feeder-id 124432-2345234-2435243-243-2435
iâm for now just looking for the file/location where it is set.
sudo piaware-config
This will show the configuration and where the settings are located.
yes - but in the there mentioned it says itâs altered by an other file âfa_piaware_configâ i do not see.
If itâs derived from the mac address it could be set automatically by FlightAware upon connection to the FA servers.
Then you would have to talk to their support to change it?
Can you post the output?
no big deal - if i do not find it i simply shut down my fa-feeds.
It seems to be feeding just fine:
https://flightaware.com/adsb/stats/user/TomMuc#stats-102721
i know. but i wanted change the idâs between the two receivers. and again i have no time for any hustle with this fa-thing. if it does not work iâll shut down both feeds.
My guess is that it needs to be changed in flightawares system.
Maybe just write a mail to adsbsupport@flightaware.com that youâd like the Radarcape to get the other feeder-id.
Or maybe @esmathews can take care of switching the feeder-id for your Radarcape to the feeder-id of your primary receiver.
Radarcapes no longer use mac address to identify themselves. They work exactly the same as a piaware installation now; feeder ID can be set in the same way as a regular piaware install.
thanx. but where is the file located or isnât it a flat-text-file anymore?
The normal way to change it is with the command i posted a few posts back, not by modifying a file.
The command will then modify /etc/piaware.conf
at least on my install.
Oh i see now, that just means that it was set via the command piaware-config
I was a little confused what you meant
Just set it, then it will be in /etc/piaware.conf
Right now itâs just in /var/cache or somewhere because it was automatically set.
But as soon as you set it manually it will be in the file.
Just do this on both receivers
sudo piaware-config feeder-id 1234-dsfs-adsf-asd
And youâll be done.
The currently used feeder-id is also written to:
/var/cache/piaware/feeder_id
But changing it there is not the way to change it.
wiedehopf that is the way i do it since years. but iâd like to know where it is saved NOW. and obviously the feeder has an feeder-id but in none of the above files it is written.
Yeah didnât quite understand what you wanted to know.
You can read out the currently used id from:
But changing that file will not change the feeder_id as far as i understand, it might though
(probably the feeder-id in that file is used when the config files donât have the feeder-id set)
(If i want to know the feeder id i normally just check the stats page, itâs noted there)
the only thing i was wondering - and maybe asked the wrong way - is:
what does the inconclusive comment in piaware.conf â# updated by fa_piaware_confâ mean?
is the value set via a piaware command or is it set by another mysterious file with the name âfa_piaware_confâ? and if so where resides âfa_piaware_confâ?
Itâs just the internal config managing part of piaware:
piaware/package/fa_piaware_config.tcl at master ¡ flightaware/piaware ¡ GitHub
Which in turn is the function called by the command piaware-config.
(âSet by piawareâ would probably make more sense?)
⌠worked. thanx
