Morning All,
We had a power outage a few days ago and it appears that the micro sd in the Raspberry Pi I use to feed is corrupt.
Whats the quickest way to get everything back up and running again without a backup of the card ?
I do have a record of my sharing codes/feeder ID’s etc. so I can reclaim the sites.
Thanks in advance
Dave
H Dave,
Burn a new card with the FA SD card image and add other feeders to it ( PiAware - build your own ADS-B ground station for integration with FlightAware - FlightAware ) or burn it with the ADSB.im image and start from there ADSB.im
Advantage of the ADSB.im image is that it installs multiple feeder software (FA,FR24, ADSB exchange among others) with just a few clicks.
Many thanks Tom you are a star Sir!
You’re welcome, good luck on rebuilding your system
Looks like it went to plan Tom and was quite painless as luckily I made a note of my sharing keys. Is this what I should be seeing or will it take time for everything to be normal?
MLAT is now green for FlightAware
Yeah Mlat usually takes some time to settle depending on the amount of additional recievers around you.
in the end it should look like this
