Didn’t say American aircraft don’t have it under the wing. Just saying it’s no longer required, although, as a spotter, I would love to see it required!
I’ll try to take some pictures when I get a chance. Oakland being Oakland, the majority of the aircraft are Southwest. The next biggest operator is Alaska. The only other aircraft I’ve seen are Allegiant, UPS, and Spirit. My break times just don’t line up with the other airlines.
Must be the viewing condition I view the Alaska 737’s under. I am literally directly under the aircraft. The bright blue sky around the aircraft evidently causes the gray to look more white.
No problemo, that is pretty damn cool you work right under a flight path! For some reason it seems almost every job I’ve ever had I’ve been able to see aircraft at a short distance.
I actually work in between 2 airports - HWD and OAK. I have no problems seeing the general aviation aircraft departing HWD because they need to make an immediate turn after takeoff due to the fact that OAK is only 5 miles away from HWD.
In Canada and most ICAO countries, if the Reg is under 12" on the tail or body you had to have the large letters under the left wing. That was the case on my Meridian were we had 7" on the rudder for looks.
