I’m just starting with FlightXML2 with Python suds and having trouble. I suspect I’m not connecting properly due to the company proxy but I don’t know where to start debugging. Please help me with some suggestions. Thanks.
ERROR:
ERROR:suds.client:<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:ns0=“http://flightxml.flightaware.com/soap/FlightXML2” xmlns:ns1=“http://schemas.xmlsoap.org/soap/envelope/” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” xmlns:SOAP-ENV=“http://schemas.xmlsoap.org/soap/envelope/”>
SOAP-ENV:Header/
ns1:Body
ns0:AirportInfoRequest
ns0:airportCodeKBOS</ns0:airportCode>
</ns0:AirportInfoRequest>
</ns1:Body>
</SOAP-ENV:Envelope>
CODE:
import sys
from suds import null, WebFault
from suds.client import Client
import logging
username = ‘xx’
apiKey = ‘xx’
url = ‘http://flightxml.flightaware.com/soap/FlightXML2/wsdl’
utrc_proxy = dict(http = ‘http://user:password@proxy:8080’)
logging.basicConfig(level=logging.INFO)
api = Client(url, username=username, password=apiKey, proxy=utrc_proxy)
print api
A = api.service.AirportInfo(“KBOS”)
print A
What’s the actual error message from suds? You’ve only included the raw dump of the SOAP request body.
Here is the suds error. Thanks for your interest.
Traceback (most recent call last):
File “”, line 1, in
File “C:\Users\georgera\AppData\Local\Continuum\Anaconda\lib\site-packages\spyderlib\widgets\externalshell\sitecustomize.py”, line 541, in runfile
execfile(filename, namespace)
File “C:/Research/BDA/code/apiTestSuds.py”, line 26, in
File “C:\Users\georgera\AppData\Local\Continuum\Anaconda\lib\site-packages\suds-0.4-py2.7.egg\suds\client.py”, line 542, in call
return client.invoke(args, kwargs)
File “C:\Users\georgera\AppData\Local\Continuum\Anaconda\lib\site-packages\suds-0.4-py2.7.egg\suds\client.py”, line 602, in invoke
result = self.send(soapenv)
File “C:\Users\georgera\AppData\Local\Continuum\Anaconda\lib\site-packages\suds-0.4-py2.7.egg\suds\client.py”, line 649, in send
result = self.failed(binding, e)
File “C:\Users\georgera\AppData\Local\Continuum\Anaconda\lib\site-packages\suds-0.4-py2.7.egg\suds\client.py”, line 698, in failed
reply = error.fp.read()
AttributeError: ‘NoneType’ object has no attribute ‘read’
