Problem with Cntrol Panel
#1
Hi
I’ve got a problem with my control panel items on my new site. It seems to be missing some fields. Any idea on how to get them back?
Old site has
Auto-update PiAware software
Mode S Multilateration (MLAT)
Send command to device
Remove Feeder Site
in the control panel but my new site control panel doesn’t have these settings. How can I get them activated please>
#2
Your new site can’t see any installed piaware debian packages so it is assuming it is a manual install and makes very few assumptions about what can be done with it.
How did you install piaware?
#3
I manually installed v3 onto my RPi3.
That’s the same way I installed my other receiver and that didn’t seem to mind on version 2.
#4
Can you explain what you mean by “manually installed”? Did you install a prebuilt package? Did you build a package from source and install that? Did you build from source and install directly without packaging?
#5
I installed it from the .deb file. I didn’t use ANY prebuilt images.
#6
But you did use the prebuilt .deb?
That should be fine. Not sure what’s gone wrong.
Can you try a “sudo dpkg --configure -a” and see if that does anything?
#7
  • Nothing showed on screen
I used this one
piaware-repository_3.1.0_all.deb
#8
I"m having the same issue.
I installed using this guide:
flightaware.com/adsb/piaware/install
I used same install method on two RPi’s at the same time, so i’m not quite sure what went wrong.
I’m new to all this, can you help?
#9
Can you both try running this (the exact command is important, make sure you get the quotes correct in particular):
dpkg-query --showformat '${binary:Package} ${Version} ${Status}
' --show '*piaware*'
and report the results?
This is the command that piaware runs to identify installed piaware packages; it is not working as expected on your systems.
#10
Just for kicks, I did it and got:
piaware 3.1.0 install ok installed
#11
piaware-repository 3.1.0 install ok installed
#12
Aha, ok, I see the bug. I’ll fix that for the next piaware release. Thanks!
In the meantime you should be able to work around it by:
piaware-config image-type piaware_package
#13
Yep that worked, thanks
Needed a sudo before the first command though
#14
Following
