Power bank as a power supply backup
Hi everyone (first post, feeder on line since yesterday).
I have a feeder version 11 and I saw 2 standard usb, 1 usb type C (the one I use for the power supply) and one more mini USB C.
Due to some power outage I was wondering if I can connect a power bank to the mini usb C and used as a backup in case of a temporary power blackout of my house. Any experiences on that?
I am just worried about the return current to the power supply when I have black out.
Many thanks
I use a backup power supply unit to hold my USB power source up during power fluctuations and it has been a great success.
Thanks for your reply, appreciated. Just one more… where do you exactly connect the external supply? Which usb?
I use the 2.0 version USB port because I have experienced compatibility issues with the 3.0 version ports with some devices that don’t speak the language.
For 2.0 you mean that you Connect an external power supply of 5 V to the “big” USB socket?
Big USB sockets can be black or blue colored. The black is the older 2.0 version and the blues are 3 versions. I have found mixing the two can cause communication issues. If you don’t know the language you can miss a few words and in the digital world that doesn’t fly well.
Gotcha. I think I will Connect my power bank into the other mini usb available. Thanks for the patience
You bet. Problem solving is a way of life for all of us.
I use these for short term UPS for Pi running Flightaware
Type-C 15W 3A 18650 Lithium Battery Charger Module DC-DC Step Up Booster Fast Charge UPS Power Supply
Not all 18650 Batteries fit. It needs the ones with the flat +ve terminal not the one with the raised terminal.
Thanks SweetPea11! I just put it into my basket and will order after this post. Regarding the connection I guess you supply your feeder directly by this small UPS and you keep on charging the UPS by the original feeder power supply (in this case your PiAware power supply). Am I right? Go to buy it :slight_smile:
Yes, but
It has a usb- c input connector so that only works if you are using a Pi 4 or Pi 5.
You will also need to supply your own cable and connector to go from the ups to the Pi. Preferably use a charging cable not just a data cable as the data cable has very fine writes that are too lossy at the required current.
You will also need to source the two batteries.
S.
batteries already have (the right ones you mentioned). My feeder is version 11 with USB C (the same socket I use to supply it) and also another one like mini USB C. So, yes I will sacrifiy another USB C and weld on the USB pcb card. It should work. Thanks again
Arrived from Ali and tested, very good product. Did some test with a Fluke multimeter and it react good. Now I will looking for a good case.
I had a power outage last night around 6:10PM local. It was only about 20 seconds, but it was enough to reset the clock on my microwave and that kind of thing. My RPi failed to reboot (no idea why), so I got an email notification at 12:10AM that it was offline. I was asleep. I didn’t realize it until this morning when I looked at my SkyAware map and it was blank. That meant I couldn’t get it back online until lunch.
So, two things:
  1. I have backup power for my home internet and my media server, but not for my feeder or my Tablo. I need to fix that.
  2. I’d like to see if FlightAware can give us adjustable notification settings? If I’d gotten the email at, say, 8:10PM or 9:10PM (2 or 3 hours after failure), there’s a good chance I could have gotten it back online before I went to sleep last night.
If you are also feeding to Flightradar24 you can set the notification to 1 hour. That has saved me multiple times since the minimum on FA is 6 hrs indeed. FR24 will send you an outage mail when you system hasn’t reported in over 60 minutes. This doesn’t happen when you are online but not sending data so that’s not covered by that function.
That’s exactly the function I’m looking for, and I am feeding FR24, so apparently I need to adjust my FR24 settings since I don’t get notifications from them at all right now.
Once logged in you can set is on the feeder page like shown below
Hello there, I cannot find that page. I am logged in, can see everything but not that one. Feeder 11 from FA. Thanks
That’s a screenshot from the flightradar24 software and not of the flightaware Feeder :wink:
LOL :face_with_tongue:.
I just spent half an hour, not that much
