adrifr
April 26, 2019, 5:12am
1
Hello all,
A small problem that, despite a lot of research on the forum, is not unresolved.
I can’t access my local data:
adress-RPI:8080 (or through the page statistics on FlightAware).
I have a raspberry PI + dump1090 mutability + other feeders functioning.
Thanks in advance for your help,
Adri-Fr
adress-RPI/dump1090/gmap.html
> MAP
adress-RPI
> Unable to connect
adress-RPI:8080
> Lighttpd Placeholder page
EDIT:
Did you install lighttpd
What is output of following command?
apt-cache policy lighttpd
adrifr:
adress-RPI:8080
You’ll have to configure that yourself.
That is only included in the lighttpd configuration for dump1090-fa, not for mutability.
Or just access your local map like described by abcd567.
adrifr
April 26, 2019, 12:52pm
4
Thank you so much !
so it is normal that when I enter the ip of my RPI:8080 it indicates a connection error?
Adri-Fr
Perfectly normal with dump1090-mutability.
The flightaware website assumes that you use dump1090-fa.
adrifr
April 26, 2019, 3:09pm
6
Thanks to you @wiedehopf (and @abcd567 of course) ! I understood my mistake.
Is it possible to install both together (mutability+fa)? I would like to keep dump1090-mutability if possible.
I wouldn’t advise it, there is not really a reason for it.
adrifr
April 26, 2019, 3:49pm
8
Noted ! Thank you so much !
1 - What are the reasons you want dump1090-fa?
2 - What are the reasons you want dump1090-mutability?
