I’ve been thinking about the choice of hardware for running 24/7 ADS-B feeders (and additional decoders like VDL2/HFDL).
Historically, the Raspberry Pi has been the undisputed gold standard for PiAware. However, with recent single-board computer price hikes, availability issues, and the easy availability of cheap used laptops/Mini PCs (like Toshiba dynabook, Fujitsu ESPRIMO, or ThinkPads), the equation seems to have shifted quite a bit!
Here is a quick comparison table based on my perspective. I’d love to hear your thoughts, experiences, or preference!
RPi Zero 2 W is definitely a great choice for sheer power efficiency and compact size for single ADS-B feeding! (Zero 3 W sounds very intriguing too.)
To be honest, I’ve actually never owned or even seen a physical Raspberry Pi in person! That’s why I initially started by installing Raspberry Pi OS on an old spare x86 PC I had lying around.
As my setup expanded to running heavy multi-decoders simultaneously (ADS-B + VDL2/HFDL), that old laptop/Mini PC route naturally became my main setup due to the CPU headroom and the built-in battery acting as a UPS.
It’s really interesting to see the different approaches based on everyone’s needs!
I have 25 stations in total, 21 are based on a Raspberry Pi 3B, 2 on a Raspberry Pi 2 and 2 are running on a Orange Pi 2+E.
Out of the 23 Pi’s 2 of them are using the ADSB.im image, 20 one of them have a package installation of FA, FR24 and Radarbox software.
One of them is running an Airspy with the needed software.
Only the Airsy is CPU hungry others are running around 15-20 % CPU use and around 25% Memory use.
23 setups are located inside with the antenna outside and connected via Ethernet. The other 2 are located outside entirely and are connected via Wi-Fi.
I like to experiment with different kind of setups so I can try all the different options and sometimes it helps me to help others in their setups when I have a similar one.
As for the antennas, most(15) of them are from Vinnant, some (8) are from Flightaware and some (2) are from Aliexpress.
Most of the setups use FA prosticks + but I also have RTL-SDR v3, Airnav Radarbox, the orange FA stick and the Airspy as SDR’s in use.
Debian 13 is living on the HP Thin clients (7) and on the 3 ESXi hosts to test with. Debian 14 is not deployed yet, once released I will install it on the ESXi hosts first to do the testing.
Built-in UPS – hadn’t thought of that for the laptop. However the battery in the laptop only powers the laptop. What if the power outage is more widespread than just your house? Then you still might not be able to receive ADS-B.
Display/Console – true if are operating the Rpi headless, you need another computer to control the Rpi using SSH. However, most people already have that other computer.
CPU/Multitasking – the additional load for dumpvdl2 multi-decoders isn’t that bad. For example I normally run dump1090-fa and dump978-fa that has a CPU Utilization of about 10% and a CPU temperature of 40 to 41 C (passive cooling). Adding in dumpvdl2 with 4 receive frequencies increases the load to about 18% and CPU temperature of 44 to 45 C. This is for an Rpi 4.
