I thought I was being excessive with 7 active Pis and an APC UPS.
And you have still place left to live and sleep?
I have 6 Pis - 1 3b, 1 3b+, 4 4b/4G - sharing 4 antennas on a UPS. My Pis also provide network printing and email services. They are mounted together in an open rack with 1¼" spacing and no fans. Temperatures range between 40°C and 50°C (ambient 25°C).
I have a Pi 1 - connected to a large powered HD via USB. The drive is partitioned and sda1 is 16GB and is the Pi operating system. Boots from the SD card then runs from the HD. Various servers installed for delivering video and audio content stored on second partition of HD.
The SD card in the Pi only has the FAT32 partition with data, the Ext4 partition is empty.
Geoff
Yep more than enough space, I use passive cooling so no noise of these Pi’s. All are strategicly out of sight so the chief of the home is also satisfied
I have all netwerk switches and the critical Pi’s covered by the UPS’es.
Flightfeeders are part of the critical Pi’s
Guess that is the most important thing.
May I ask what passive cooling you are using?
I have heatsinks on the hot components and use armor cases for the Pi’s. For the Orange Pi’s I have custom made casings , had a small batch made consisting of 4 metal plates that are curved around the boards in order to create the heat transfer
Hi guys n girls,
I am looking for some assistance. I keep getting the notification as discussed further up the thread “you’re piaware is running at 76© move it out the sun or use heatsinks” on the flightaware settings page.
It’s really really hot here in Scotland UK just now so I know it’s not down to overrunning the pi3b+.
I have an EasyAis GPIO Hat and FA Pro stick + running AIS dispatcher NMEA multiplexer, FA, Adsb exchange and VRS feeder.
I thought perhaps running all that may have been the problem but everything was fine until the sun came out.
My problem is my GPIO is obviously tied up with the ais hat and this is also covering the components to be cooled.
Can anyone recommend:
- a neat kinda box I can just strip it all out of its current standard black case and add a fan or two inside of?
- a way to maybe install a gpio fan hat but still keep the ais hat running?
Any help is greatly appreciated as last thing I want is for my stationto melt or stop working.
Hope you’re all well. Thank you
Regards
This is how I cool my Pi, huge 12V fan gently running @ 7VDC, practically no noise and much better cooling.
Without wishing to sound rude - but what passes for “really really hot” in Scotland?
Pi 4’s do run hotter than previous models, so heatsinks are well advised (and helpful when your fan fails).
At least there was a series at the beginning with massive temperature problems, but these should be sorted meanwhile. A friend of mine “lost” his first device due to heat.
However good cooling is always advised.
My device runs outdoor where we have +35°C or even more as peak. I never brought mine with active Armor cooling higher than 65°C…
I would be surprised if Scotland is really really hotter
This is the current temperature with a connected Airspy and a setting using 80% of a single core CPU
Hello,
OK cheers for the replies. Right now I don’t have a fan because of the AIS hat in the way of the board.
I am only going by the 70- 74c warnings I keep receiving through the piaware settings page and assume I should apply either heatsinks or a fan soon?
On touching the casing of the pi 3 it is hot to touch.
The “really really hot” is contrary to the really really cold weather we normally face here
I am considering transferring my 3B setup over to my pi4b argonone and placing the AIS hat on a gpio extension cable (I have to do this because the argon case prevents me from mounting the AIS hat straight to the GPIO)
At least if I do it this way the pi /FA dongle will be cooled by the argon Fan hat.
Just wanted to see what you guys thought?
Are the 70-74c warnings normal at times then?
Managed to acquire this fan from a broken ps3… after much unscrewing and prising apart, maybe this will do if I can find a suitable 12v 2A psu for it?
Thanks again everyone
HeHe! That’s what I thought
74C is hotter than I’d like for mine, but it is below throttling temp, so it should be ok.
Your fan may be rated 12V, but it you have a variable PSU (you other hobbys suggest you might), you can see what voltage it will reliably start - it may be fine at 5V and be silent too.
I repeat myself using an Armor case. This is available in two flavors. One passive and the other one with active fans. These can be connected to 3 and 5V which changes the speed and therefore the noise
The whole case is the heatsink and i think that makes it pretty efficient
Four, not two.
The ‘bikini’ version finishes behind and flush with the connectors (RJ45 & USB).
The ‘one piece’ is full size and covers the connectors (my preferred style).
Either is good, but I like full length style, but it doesn’t expose the GPIO header.
The downside is none are suitable if you want use a hat.
Did not think about that, good point. I was focussed on the “bikini” version only.
I like this term, will use it from now on
Not all of them. The new Joy-it ones don’t have that option
For sure, the fans have two connectors. Some are joined in one piece, but can be splitted by short extension cables.
Or if you are brave enough, cut them right above the connector.
It’s more difficult, but not impossible.
And it’s not a problem of Joy-it. Many others selliong the cases and fans with different connectors. Some of us have luck, others not.
I have two of these, one with a joined connector, the other one with two individuals
This topic was automatically closed 365 days after the last reply. New replies are no longer allowed.
