Hey, when my next N2+ arrives, I am going to set up using your auto gain scripts with a prostick plus, to compare with the recent airspy auto gain developments. But I want to also feed flightradar24 from it. Can you point to the script install to add FR24 to your setup??
FR24 has only armhf, amd64 and i386 packages.
They dont have arm64 package (yet).
Depends what is supported by N2âs OS.
The 64 bit Raspbian on Pi 4 supports both arm64
and armhf
architectures, as shown below:
$ dpkg --print-architecture
arm64
$ dpkg --print-foreign-architectures
armhf
Therefore Flightradar24âs armhf package can be installed on both the (Pi4+ 64-bit Raspbian) and (Pi4+32-bit Raspbian) by their standard bash-script given below:
sudo bash -c "$(wget -O - https://repo-feed.flightradar24.com/install_fr24_rpi.sh)"
Ahh ok, thanks for that. I like the (yet) part, obviously you believe that this may come along. But other than that, using a prostick out of a N2+ with the appropriate OS shouldnât be a problem with your adaptive gain?
Cant say. Neither have N2 to test, nor got any feed-back from any N2 owner about it.
Well a N2 running your adaptive gain scripts, using a Prostick plus. However, tried installing wiedehopfâs graphs to monitor the adaptive gain and I know there has been a lot of modifying that graph system, with the airspy project currently running and the current download for the graphs, is not working with this adaptive gain. Any suggestions??
Sorry, fixed. Missed last step re problem with his graphs and Ubuntu 20 OS. working now
The Adaptive Gain is by Oliver Jowett (@obj), and not by me.
I have only written the bash-script to build and install dump1090-fa using source code authored by Oliver (@obj) and available at Flightawareâs Github Repository.
What are the outputs of these two commands?
arm64
root@odroid:~#
To install FR24 armhf feeder, try this:
sudo dpkg --add-architecture armhf
## Update apt
sudo apt-get update
## Check
Last command above should output armhf.
Now run FR24 bash script to install their feeder fr24feed:armhf
Â
The result for the foreign enq was armhf. Tried your next script, got errors, but before posting, isnât that last script the RPI install for FR24??
it is said âinstall_fr24_rpi.shâ because it was originally designed for RPi, but should install on any board with armhf/arm64 cpu, provided itâs OSâs repository can provide dependencieâs 32-bit packages.
As RPiâs current OS is basically Debian Buster, you may try Armbian Buster instead of Ubuntu to make your Ordoid operationally similar to RPi.
https://www.armbian.com/odroid-n2/
https://redirect.armbian.com/odroidn2/Buster_current
Yes that is what I am thinking re other issues with Ubuntu OS. I shall advise. Now currently have the FA prostick attached. Could I attach an airspy to this and try the adaptive gain with that??
I have no idea about AirSpy (I dont have one). Better ask in AirSpy thread.
I am successfully running ver 6.1 and FR24 on an Odroid N2 under Armbian. Adaptive gain seems to be working ok with my FA RTL Prostick, my understanding is that FA adaptive gain will not work with an AirSpy Rx.
Thanks, I thought the airspy might not like adaptive gain, just a thought. Changing over to buster now and will use ABCDâs scripts above to try FR24
Youâre not grasping how dump1090-fa / airspy_adsb interact.
dump1090-fa has no gain to adjust because it isnât controlling the SDR but rather only receiving data via the network.
The settings regarding gain are preobably just ignore in that case.
FR24 feed working. FULL STOP END OF STATEMENT. With Armbian buster adaptive gain set up, thanks, now to compare with the airspy auto gain project.
Gain settings are only important with the decoder.
The data going to other feed clients is not affected by it.
Just for you. Go back and see the edit so you donât get confused again.
