Installation on Arch Linux amd64
(1) DUMP1090-FA
Follow procedure here:
https://github.com/abcd567a/dump1090-fa-arch/blob/master/README.md
(2) PIAWARE:
https://github.com/abcd567a/piaware-arch/blob/main/README.md
CLICK ON SCREENSHOT TO SEE LARGER SIZE
[abcd@archlinux2021 ~]$ sudo systemctl status piaware
● piaware.service - FlightAware ADS-B uploader
Loaded: loaded (/usr/lib/systemd/system/piaware.service; enabled; vendor preset: disabled)
Active: active (running) since Mon 2021-09-06 18:13:44 EDT; 18min ago
Docs: https://flightaware.com/adsb/piaware/
Main PID: 306 (piaware)
Tasks: 4 (limit: 3565)
Memory: 39.8M
CPU: 4.139s
CGroup: /system.slice/piaware.service
├─ 306 /usr/bin/piaware -p /run/piaware/piaware.pid -plainlog -statusfile /run/piaware/status.json
├─ 748 /usr/bin/python3 /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,conn>
└─1834 /usr/lib/piaware/helpers/faup1090 --net-bo-ipaddr localhost --net-bo-port 30005 --stdout --lat 43.5xxx --lon -79.6xxx
Sep 06 18:24:24 archlinux2021 piaware[306]: 1160 msgs recv'd from dump1090-fa (658 in last 5m); 1160 msgs sent to FlightAware
Sep 06 18:24:31 archlinux2021 piaware[306]: mlat-client(748): Input connected to localhost:30005
Sep 06 18:24:31 archlinux2021 piaware[306]: mlat-client(748): Input format changed to BEAST, 12MHz clock
Sep 06 18:24:31 archlinux2021 piaware[306]: mlat-client(748): Beast-format results connection with ::1:30104: connection established
Sep 06 18:29:24 archlinux2021 piaware[306]: 2038 msgs recv'd from dump1090-fa (878 in last 5m); 2038 msgs sent to FlightAware
Sep 06 18:29:54 archlinux2021 piaware[306]: mlat-client(748): Receiver status: connected
Sep 06 18:29:54 archlinux2021 piaware[306]: mlat-client(748): Server status: connected
Sep 06 18:29:54 archlinux2021 piaware[306]: mlat-client(748): Receiver: 78.7 msg/s received 34.7 msg/s processed (44%)
Sep 06 18:29:54 archlinux2021 piaware[306]: mlat-client(748): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.4kB/s UDP to server
Sep 06 18:29:54 archlinux2021 piaware[306]: mlat-client(748): Aircraft: 5 of 8 Mode S, 20 of 24 ADS-B used
