I had an issue with my previous image on my PiAware so i re-flashed the SD card. followed the directions at https://flightaware.com/adsb/piaware/install. completed the entire directions after the reboot, the Pi boots up like normal but will not launch the Flight aware software.
"Placeholder page
The owner of this web site has not put up any web pages yet. Please come back later.
You should replace this page with your own web pages as soon as possible.
Unless you changed its configuration, your new server is configured as follows:
Configuration files can be found in /etc/lighttpd. Please read /etc/lighttpd/conf-available/README file.
The DocumentRoot, which is the directory under which all your HTML files should exist, is set to /var/www/html.
CGI scripts are looked for in /usr/lib/cgi-bin, which is where Debian packages will place their scripts. You can enable cgi module by using command "lighty-enable-mod cgi".
Log files are placed in /var/log/lighttpd, and will be rotated weekly. The frequency of rotation can be easily changed by editing /etc/logrotate.d/lighttpd.
The default directory index is index.html, meaning that requests for a directory /foo/bar/ will give the contents of the file /var/www/html/foo/bar/index.html if it exists (assuming that /var/www/html is your DocumentRoot).
You can enable user directories by using command "lighty-enable-mod userdir"
About this page
This is a placeholder page installed by the Debian release of the Lighttpd server package.
This computer has installed the Debian GNU/Linux operating system, but it has nothing to do with the Debian Project. Please do not contact the Debian Project about it.
If you find a bug in this Lighttpd package, or in Lighttpd itself, please file a bug report on it. Instructions on doing this, and the list of known bugs of this package, can be found in the Debian Bug Tracking System."
for the “curl -s http://ip_address | grep ADS-B” (i SSH from windows 10 to Pi) i get nothing.
the Pi boots, but i just get the command prompt login. normally i would get the PiAware 8.2 splash screen followed by the 4 status of:
so i had a power outage last night. after power came back the raspberry pi boots but only asks of username and password does not load pi-aware. any ideas what to do to get it to reboot?
