Piaware local network?
Hi, I’ve got piaware running in a Pi0w and it was working great. Since then I have moved and have no WiFi but would still like to view the piaware ADSB map.
Is there a way to setup a WiFi network broadcast directly from the Pi that I can connect to sort of like a hotspot?
Raspberry Pi Documentation - Configuration
Without internet connection (to the Desktop/Laptop on which you will view the map), the SkyView/dump1090-fa map will NOT download & display map tiles. You will see airplanes on a blank page.
When I travel and take a Pi with me I turn on the Wi-Fi hotspot in my Android phone and use the same SSID and password as my Wi-Fi network at home.
The Pi then just connects to the hotspot and behaves as normal.
My tablet connects to the same hgotspot so I can still see the Skyview/Skyaware map of the planes in range.
I usually turn off MLAT as it significantly increases the data traffic on my phone.
S
If you have a hard-wired network, you can still connect the Raspberry Pi to your network using an Ethernet cable plugged into the Pi’s Enternet port. You can then plug in a RTL-SDR dongle and attach an antenna to it, and receive and share aircraft transponder signals. The software in the PiAware package doesn’t care whether you are connected wired or wireless.
