Piaware installation certificate is expired, TLS error and no connection to FA
It seems a certificate is expired, I reinstalled Piaware on a system Site 153719 to be exact and now it isn’t able to connect to the piaware server anymore:
Dec 06 18:16:59 raspberrypi17tom piaware[11933]: TLS alert (write): certificate expired
Dec 06 18:16:59 raspberrypi17tom piaware[11933]: TLS error: certificate verify failed
Dec 06 18:16:59 raspberrypi17tom piaware[11933]: TLS handshake with adept server at piaware.flightaware.com/1200 failed: handshake failed: certificate verify failed
Dec 06 18:16:59 raspberrypi17tom piaware[11933]: reconnecting in 6 seconds…
@obj could you alert someone to get this fixed?
I think someone has to fix the certificate, in the meantime, don’t lose your connection since you won’t be able to get reconnected after a reboot :wink: :smiling_face_with_sunglasses:
I will probably lose my streak on this system, unless they are able to fix it withinh 24 hrs
Running into same issue.
You’re right. Rebooted one of my systems and it now shows same error messages as above.
Same here. Seems that this is not their first rodeo too :wink:
Looks like their cert expired today?
2025-12-06T14:01:05.066121-05:00 piaware-iad piaware[22145]: Connecting to FlightAware adept server at ``piaware.flightaware.com/1200
2025-12-06T14:01:05.121520-05:00 piaware-iad piaware[22145]: Connection with adept server at ``piaware.flightaware.com/1200`` established
2025-12-06T14:01:05.439019-05:00 piaware-iad piaware[22145]: TLS verify failed: certificate has expired
2025-12-06T14:01:05.439227-05:00 piaware-iad piaware[22145]: Failing certificate:
2025-12-06T14:01:05.439352-05:00 piaware-iad piaware[22145]: sha1_hash: D191B12012733E764CA27D5DFB88336499C9C7C1
2025-12-06T14:01:05.439458-05:00 piaware-iad piaware[22145]: subject: CN=FlightAware Intermediate,OU=Operations,O=FlightAware LLC,ST= TX,C=US
2025-12-06T14:01:05.439579-05:00 piaware-iad piaware[22145]: issuer: CN=FlightAware Root,OU=Operations,O=FlightAware LLC,L=Houston,ST =TX,C=US
2025-12-06T14:01:05.439694-05:00 piaware-iad piaware[22145]: notBefore: Dec 9 16:59:51 2015 GMT
2025-12-06T14:01:05.439793-05:00 piaware-iad piaware[22145]: notAfter: Dec 6 16:59:51 2025 GMT
2025-12-06T14:01:05.439906-05:00 piaware-iad piaware[22145]: serial: 2048
Can confirm on my #219175 as well. Shut down for a hardware change, came back up with same error. Local display shows planes received so all is working, just the certificate issue.
Happened RIGHT after issuing an apt update command. Have been troubleshooting for nearly two hours to figure out what I broke.
Relieved to find it is not on my end.
The same issue appeared 10 years ago, when searching for this error I found the old post and that is almost identical to this issue.
Same here cert expired today
Same here. And to think, I was all proud of myself for finally cleaning up the wires for my attic installation. Teaches me for rebooting the dang thing. I’m guessing we wait for a new package?
Edit:
I’ll also note the remote server isn’t even acknowledging a ClientHello. It just drops connection.. that’s showing up in the log as an eof, but a little more detailed when connecting with openssl.
Saw an alert about errors several hours ago and just now got a chance to dig into the logs and look, seeing the same thing.
[2025-12-06 16:24:05.241][piaware] Failing certificate:
[2025-12-06 16:24:05.241][piaware]   sha1_hash: D191B12012733E764CA27D5DFB88336499C9C7C1
[2025-12-06 16:24:05.241][piaware]   subject: CN=FlightAware Intermediate,OU=Operations,O=FlightAware LLC,ST=TX,C=US
[2025-12-06 16:24:05.241][piaware]   issuer: CN=FlightAware Root,OU=Operations,O=FlightAware LLC,L=Houston,ST=TX,C=US
[2025-12-06 16:24:05.241][piaware]   notBefore: Dec  9 16:59:51 2015 GMT
[2025-12-06 16:24:05.241][piaware]   notAfter: Dec  6 16:59:51 2025 GMT
[2025-12-06 16:24:05.241][piaware]   serial: 2048
AHA! That must be the source of my issue. I have not restarted one of my feeders. I restarted the other one only after the problem started.
Probably will happen ten years from now, since it looks like they use 10 year certificates. :slight_smile:
Same issue for me, just finish doing a fresh install of my setup and bang.
Same issue here, did some network changes earlier today and thought I broke something.
I am seeing the same thing, did update and could not reconnect, tried backup system, same result.
Nope we wait for the certificate to be renewed and then you should be able to connect again. It’s a serverside issue that has to be fixed by FA, nothing we as user can do at the moment, just be patiënt since it is the weekend this might be resolved on Monday, hopefully sooner but I wouldn’t count on it :smiling_face_with_sunglasses:
Interesting thing in the logs, is that the expired certificate may be an intermediate CA in the path?
This is what I’m logging but have not yet dug into the cert:
[2025-12-06 18:51:10.016][piaware] reconnecting in 5 seconds...
[2025-12-06 18:51:15.017][piaware] Connecting to FlightAware adept server at 206.253.84.196/1200
[2025-12-06 18:51:15.057][piaware] Connection with adept server at 206.253.84.196/1200 established
[2025-12-06 18:51:15.163][piaware] TLS verify failed: certificate has expired
[2025-12-06 18:51:15.163][piaware] Failing certificate:
[2025-12-06 18:51:15.163][piaware]   sha1_hash: D191B12012733E764CA27D5DFB88336499C9C7C1
[2025-12-06 18:51:15.163][piaware]   subject: CN=FlightAware Intermediate,OU=Operations,O=FlightAware LLC,ST=TX,C=US
[2025-12-06 18:51:15.163][piaware]   issuer: CN=FlightAware Root,OU=Operations,O=FlightAware LLC,L=Houston,ST=TX,C=US
[2025-12-06 18:51:15.163][piaware]   notBefore: Dec  9 16:59:51 2015 GMT
[2025-12-06 18:51:15.163][piaware]   notAfter: Dec  6 16:59:51 2025 GMT
[2025-12-06 18:51:15.163][piaware]   serial: 2048
[2025-12-06 18:51:15.163][piaware]   certificate: -----BEGIN CERTIFICATE-----
[2025-12-06 18:51:15.163][piaware] MIIFxDCCA6ygAwIBAgICIEgwDQYJKoZIhvcNAQELBQAwdjELMAkGA1UEBhMCVVMx
[2025-12-06 18:51:15.163][piaware] CzAJBgNVBAgMAlRYMRAwDgYDVQQHDAdIb3VzdG9uMRgwFgYDVQQKDA9GbGlnaHRB
[2025-12-06 18:51:15.163][piaware] d2FyZSBMTEMxEzARBgNVBAsMCk9wZXJhdGlvbnMxGTAXBgNVBAMMEEZsaWdodEF3
[2025-12-06 18:51:15.163][piaware] YXJlIFJvb3QwHhcNMTUxMjA5MTY1OTUxWhcNMjUxMjA2MTY1OTUxWjBsMQswCQYD
[2025-12-06 18:51:15.163][piaware] VQQGEwJVUzELMAkGA1UECAwCVFgxGDAWBgNVBAoMD0ZsaWdodEF3YXJlIExMQzET
[2025-12-06 18:51:15.163][piaware] MBEGA1UECwwKT3BlcmF0aW9uczEhMB8GA1UEAwwYRmxpZ2h0QXdhcmUgSW50ZXJt
[2025-12-06 18:51:15.163][piaware] ZWRpYXRlMIICIjANBgkqhkiG9w0BAQEFAAOCAg8AMIICCgKCAgEAnUX7pIQ/GhJc
[2025-12-06 18:51:15.163][piaware] I0JMkxsFz4+0E2n7ZYfEawO0ESAoXOq20iy/PTg7/VFkwmt6ksAcY9Wg0AFYiXtq
[2025-12-06 18:51:15.163][piaware] tddB5tl76MuwKhtt0qPcVyvoGZN4jkrKevRipCTqyuPlvCcBMsE81kPFhP7JOKnu
[2025-12-06 18:51:15.163][piaware] wKGGQnj9Oq3Ljd/8Xv8wZUY+BkDUPohAHthCgcWlesSDp2HJO4hxb2Jrzv+dR7gD
[2025-12-06 18:51:15.163][piaware] Z+0+S4n3IiC2SJt50eF5SKeH7crnIfs52vtyzV8UtGyjxtvreNpnH9cXE66BVp0F
[2025-12-06 18:51:15.163][piaware] f1ES4h7T9WtrvUNaVEqHzAL+F9akk2UHPSeL6VZ4RALMSFnHCW/TezU6M4I9TAdc
[2025-12-06 18:51:15.163][piaware] N8h16+krE9O7Ad2wpWNqwVajbsD3+dZk+sIf8rQEf/7ptJxSnZYGFhLymIP3NEzo
[2025-12-06 18:51:15.163][piaware] tKyM2rZGyZU2+f6Nvdtx5zPOwJoK6gmf3pfJZOmsT2JrGKi0wejfP5ZR2mdNB9F2
[2025-12-06 18:51:15.163][piaware] o38+YT1tA7j4LJSk3NKv6I6MeAnxxgQf6A4FjRxfMpQi0L1gZHN6cpykDs7NetZR
[2025-12-06 18:51:15.163][piaware] QBGsIzopLuiPYOBnkEH6dZ/Sp2WweB880Wxn3txAMQmKZ7r8K0jC5o30/nQmsRR4
[2025-12-06 18:51:15.163][piaware] sIRp+FbP+6RcdTBO7hz0419Bbm6sobXT7iGz01pwlzcqkdBr2uRDqwV897B6HPOs
[2025-12-06 18:51:15.163][piaware] jqsREayKk3fVCUTYMuRYem0rAfOIeeMCAwEAAaNmMGQwHQYDVR0OBBYEFF1sXfss
[2025-12-06 18:51:15.163][piaware] NOpvCNJ7EkXfa8meNnAzMB8GA1UdIwQYMBaAFIuGshfXL5BrwS82l+kloZGxM0PA
[2025-12-06 18:51:15.163][piaware] MBIGA1UdEwEB/wQIMAYBAf8CAQAwDgYDVR0PAQH/BAQDAgGGMA0GCSqGSIb3DQEB
[2025-12-06 18:51:15.163][piaware] CwUAA4ICAQC87Y+f6FU2lrpxnaN2RS/sHtHTFtBQa/WbgjxaAhJ3hAslU6p8wqhC
[2025-12-06 18:51:15.163][piaware] Dhsxoh/g9PFjNAK845xeQx1/7PTU68dnTT2J21891DI0xhNAOgUDeztQBTclt5Jx
[2025-12-06 18:51:15.163][piaware] WIQDzOBXaDbFwdv9UOYjoujql2Ei6ZR1NK6SYIrB7Gmx7weMzfj7BRyfij4XQR2R
[2025-12-06 18:51:15.163][piaware] B/DVYszH//7Dw2IwavEM0VYPJZsoldTbC3onspnjY/O2yXufzlPvJr1upsawGQvS
[2025-12-06 18:51:15.163][piaware] 9fPhcftWuEp3L3YhIGCksy7q1UnT7RgdXlEIj1waSkX1RMwkJF7JJEUDZ1A3rVNF
[2025-12-06 18:51:15.163][piaware] GFHwjx79M2XPeWV/4BOq2SVY2rqMUWckol2NlFfu3sxVlDSAQspqrzrG7jzKfGrA
[2025-12-06 18:51:15.163][piaware] 4dHjkRWR9fwykIGgjUDme0aN/oE6vJixvf5JqMnDBCoUZJpUVuAe29hxoWL2Mrdj
[2025-12-06 18:51:15.163][piaware] Scn/vA8lDYFypVRHibX07/s9p/mims/YWzusFiLS2u186bDNyQANk2gccxGSpuBK
[2025-12-06 18:51:15.163][piaware] TGAwDug34UjiVYlXDUIs4RpAsYqnRUiHGF/TzeuDAhKPZJPrUfCrSgEpOERbFSFx
[2025-12-06 18:51:15.163][piaware] E1v4/2C3n1uo27HE1xdEdfghjGmW+mOO7zbnulKSEsanUxK0HVlzHlzrgxVcqGEc
[2025-12-06 18:51:15.163][piaware] 3lZxyDutYoH0WpxIut41bMBOPDepqMKXzUbKz1YxSsC2Sb05K1ZrDg==
[2025-12-06 18:51:15.163][piaware] -----END CERTIFICATE-----
[2025-12-06 18:51:15.163][piaware] TLS alert (write): certificate expired
[2025-12-06 18:51:15.163][piaware] TLS error: certificate verify failed
[2025-12-06 18:51:15.163][piaware] TLS handshake with adept server at 206.253.84.196/1200 failed: handshake failed: certificate verify failed
[2025-12-06 18:51:15.164][piaware] reconnecting in 61 seconds...
[2025-12-06 18:51:19.777][dump1090] adaptive: reached upper gain limit, halting dynamic range scan here
[2025-12-06 18:51:33.730][piaware] 72 msgs recv'd from dump1090; 0 msgs sent to FlightAware
[2025-12-06 18:52:16.165][piaware] Connecting to FlightAware adept server at piaware.flightaware.com/1200
[2025-12-06 18:52:16.211][piaware] Connection with adept server at piaware.flightaware.com/1200 established
[2025-12-06 18:52:16.268][piaware] TLS alert (write): decode error
[2025-12-06 18:52:16.268][piaware] TLS error: unexpected eof while reading
[2025-12-06 18:52:16.268][piaware] TLS handshake with adept server at piaware.flightaware.com/1200 failed: handshake failed: unexpected eof while reading
[2025-12-06 18:52:16.268][piaware] reconnecting in 6 seconds...
[2025-12-06 18:52:22.269][piaware] Connecting to FlightAware adept server at piaware.flightaware.com/1200
[2025-12-06 18:52:22.315][piaware] Connection with adept server at piaware.flightaware.com/1200 established
[2025-12-06 18:52:22.354][piaware] TLS alert (write): decode error
[2025-12-06 18:52:22.354][piaware] TLS error: unexpected eof while reading
[2025-12-06 18:52:22.354][piaware] TLS handshake with adept server at piaware.flightaware.com/1200 failed: handshake failed: unexpected eof while reading
[2025-12-06 18:52:22.357][piaware] reconnecting in 4 seconds...
Actually, the cert that’s expiring isn’t the server cert.. it’s the FlightAware Intermediate certificate that’s packaged with the distribution. That intermediate lives on the client side and is what PiAware uses to decide whether it trusts the server’s certificate when it connects.
Even if FA updates their server cert, the connection will still fail until a new intermediate is provided through a client update or other means. Fingers crossed for a speedy resolution!
Yeah, its definitely the intermediate :grimacing:
