If you have a spare microSD card, burn latest Piaware image, swap old card by newly burnt one and see if it works. This will show if the problem is in Pi’s software or somewhere else.
P.S.
Do not forget to create a blank file named ssh (or ssh.txt) in /boot folder of newly burnt microSD card while the card is still plugged in the card reader of your Windows computer. This is ecessary to enable SSH.
You have to copy Unique Identifier from your Flightaware stats page and give following command after boot sudo piaware-config feeder-id xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
Where xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx is Unique-id you copied from your flightaware page.
Got similar problem last year. Twice. It turned out that the problem was in degraded microSD card in both cases (both were the same brand). If all was OK for 4 years it is time to expect problems with the card. Try to swap it
I used to think the same way about re-imaging the SD card. But it literally takes minutes. If you follow the steps mentioned (empty SSH file at root, and feeder id ‘transfer’), it’s painless.
I would add the SSID and password, if you plan on using Wi-Fi.
Well, I don’t think it is my SD Card. Here is what I did and why I think that…
Opened a brand new SD Card and copied the image backup that I had made in DEC2017 (about 4 months ago).
Put the newly imaged SD Card into the PI. It booted fine. Exact same symptoms. Since PiAware was working great in DEC2017 off the copied image and I put that image onto a new SD Card. Nothing, IMO, points to a bad SD Card.
I really feel is has ‘something’ to do with this ./dump1090 message.
I would except this command to load a text table of flights being tracked. As a reminder, I see the planes being tracked on the live link map web display (http://192.168.1.2:8080 in my case) just fine.
(Do Not forget to add file ssh in /boot folder while card is still in card reader of Windows computer, add your feeder-id immediately after first boot, and configure WiFi in file piaware-config.txt in /boot folder, if you are using WiFi instead of Wired Ethernet).
You have to first STOP the current instance of dump1090.
Use one of the 3 commands below depending on version of dump1090 you are using,
If you are not sure of version of dump1090, issue all the three commands.
sudo service dump1090 stop
sudo service dump1090-fa stop
sudo service dump1090-mutability stop
Now test :
cd dump1090/
./dump1090
P.S.
After test, restart dump1090
sudo service dump1090 restart
sudo service dump1090-fa restart
sudo service dump1090-mutability restart
Ok… “cat /etc/os-release" tells me I’m on jessie now. (that took awhile…)
Did all the other house cleaning as well. Rebooted and I gotta run. Hopefully I will see planes logged soon, but I’m not hopeful. If this doesn’t work I ?think? FA has a PiAware image somewhere and I will just load that.
After burning the image to microSD card, and while the microSD card is still plugged into yiur computer, open the microSD card in file explorer, and create a file named ssh (or ssh.txt). This is necessary to enable SSH.
With a fresh install, by default Flightaware assigns a new feeder ID, but you can use your old feeder ID if you want.
OK… Here’s where we are. I downloaded and installed the new piaware img (thx). I can click on “view live data” and I see a fancier plot of the planes than I used to have. So, the Rx side is still working. But, take a look at the screen shot. I am still not connecting to FA to send my data.
Possible a router problem on my end? I am direct connect; not WiFi connected for this RasPI.
If you get a prompt you are connected.
If you don’t get a prompt then something is blocking port 1200.
I have seen other ports being blocked but 1200 has been fairly open. You would need to either check your router settings for outgoing TCP ports OR ask your ISP if outgoing TCP port 1200 packets are blocked.
Some secured networks (corporate networks and schools) will block all packets not on specific ports.
Thx for the guidance. OK… I’m on a home network and I am my own IT Manager (for better or worse).
The “telnet piaware.flightaware.com 1200” returns “Trying…” for a few minutes then “tries” some more.
I guess that tells up PORT 1200 is blocked? I have a new’ish Sagemcom F@st 5260 router(issues by Time Warner) and I have to say the firewall setting is different than what I am used to seeing. I have opened a few PORTS in my day, but maybe not Telnet. See the screenshot below. Two things: It does not let me select 1200 and should what should the accept/reject pull down be set to?
I pass the TELNET to port 1200 with the web tool. This makes things even more confusing. It means my router is not blocking, but the PiAware PI is not ‘getting out’. Grrrrrr. I’m getting frustrated,
I have network wires o’plenty so I opened a brand new one that hasn’t seen electrons since it left the factory and rebooted the PI. SSH’d into it and ran the telnet command to PORT 1200.
And… no change. TELNET is stuck at “Trying…”.
This is a real head scratcher for me. First off because the PI set up stopped sending to FA after 4 years. Then I have the same problem (basically) after loading a fresh PiAware dedicated image.
I’m still open to any ideas, but I am considering fire.
OK. The plot thickens. I decided to take a break from this FA project and play ham radio.
I now have noticed that any website that includes a PORT number is off limits to my internet connection. This includes my RasPI VPN setup.
For example, I am not able to goto http://w5cqu.homeip.net:8100/ on my PC while connected to my Time Warner internet connection. However, if I connect my PC to the internet via a hotspot connection on my phone all is well. Sounds like my beef is with Time Warner?
