Thanks for help. deleted some of the less relevant posts. can delete more
This also fixed it for me after updating piaware…Thanks!
Did you guys know PiAware 5.0 Image has a broken NTP Time Sync! I had a hard time to set it up via online tutorials…
#piaware
#flightaware
I’m not aware of any NTP problems with the 5.0 image. What’s the problem you ran into?
Note that the piaware images include a full ntpd. Base Raspbian defaults to systemd-timesyncd which is somewhat more limited. You should use ntpq
to look at ntp status, not timedatectl
(timedatectl looks at systemd-timesyncd’s status, and that’s not in use on piaware images)
5.0 image here, no special config; it’s synced to a stratum 1 server to within about 0.5ms:
pi@piaware:~ $ ntpq -p
remote refid st t when poll reach delay offset jitter
0.debian.pool.n .POOL. 16 p - 64 0 0.000 0.000 0.001
1.debian.pool.n .POOL. 16 p - 64 0 0.000 0.000 0.001
2.debian.pool.n .POOL. 16 p - 64 0 0.000 0.000 0.001
3.debian.pool.n .POOL. 16 p - 64 0 0.000 0.000 0.001
-itachi.nerzhul. 202.156.0.34 2 u 780 1024 377 2.812 1.075 0.555
*210.23.25.77 .GPS. 1 u 92 1024 377 3.216 0.462 1.002
+any.time.nl 202.156.0.34 2 u 1702 1024 376 3.853 0.544 0.620
-ns-vultr.nono.i 218.73.139.35 2 u 117m 1024 100 2.855 -1.908 2.253
-178.128.28.21 210.23.25.77 2 u 912 1024 377 17.247 2.358 2.598
+ntpmon.dcs1.biz .PPS. 1 u 855 1024 377 3.142 0.353 0.585
I’ve two days ago run across issues with the ntp service just not working with zero explanation of why. (current raspbian i believe)
ntpdate would work without issues.
removing ntp and installing chrony instantly fixed the issue.
ntpd would say “soliciting” in the journal but never get any peers when checking with ntpq -p
My feeder has apparently upgraded itself to 5.0…
I’m still feeding all sites but I can’t connect to any of the services on the RPi.
Connection is refused, can’t view SkyAware, tar1090 or graphs or anything else.
Does anyone know why and how I solve this?
IP/skyaware/ will do the trick
Run tar1090 update will likely fix it. (lighttpd is hard to make work with multiple parties using the config stuff)
Once again, you’re the man!
