Transferred to new Pi 5 but SkyAware won’t come up. Rebooted/updated PiAware and 1090 under Stats, but no response
You probably need to either rebuild the OS ( hardware differences between Pi 4 and Pi 5) or download the image and start from there.
When switching between hardware versions you might have an issue with a missing driver.
Also you could connect a screen and mouse/keyboard to see what the Pi5 is reporting on boot in order to troubleshoot it.
After you have the Pi 5 up and running you can transfer the old site number to it again
I reflashed the img file, changed config txt for wifi, inserted in new Pi, red solid light with green flashing, under Stats, rebooted Pi and 1090 dump. SkyAware still not tracking. I noticed there was no logging activity under site configuration.
Thanks, Paul
Check if you haven’t created a second reciever on your stats page. Since you use the image it might be the case and you will need to revert its unique identification number to the old one.
Now that I’ve changed to a new Pi, how do I transfer the old site number to the new Pi, in the config txt file? Stats still show my original site #
follow the steps in this post:
Add the sudo commands under “piaware-config.txt” ?
no, you have to execute those via SSH login into the system.
Thanks for your help. I don’t recall ever using Putty for FA. Is Putty the only way to insert Unique Identifier?
One place in Topics showed just to add the 2 sudo cmds under the Piaware config. That didn’t work.
Yo have to edit the config file and to do that you will need an interface towards the configuration.
That’s why you would need Putty.
Maybe someone else can tell you other ways but I always have used this tool.
PIAWARE SD CARD IMAGE
(1) Insert microSD card in a USB card reader, and plug the card reader in your Windows Computer
(2) Go to Windows Explorer and click on the microSD card’s drive letter, normally labelled bootfs, to open folder /boot
(3) To enable SSH, in folder /boot create a blank text file and rename it ssh
(4) In file /boot/piaware-config.txt
(a) Add actual vale of ssid in place of “MyWifiNetwork” and actual wifi password in place of “s3cr3t99” in following lines
wireless-ssid MyWifiNetwork
wireless-password s3cr3t99 -
(b) Scroll down to the bottom of file
piaware-config.txt, and below the last line which is:
# Additional settings can be added below.
add following
feeder-id xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
NOTE:
(1) there i no “sudo piaware-config” in this line
(2) Replace xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx by your actual feeder id)
Can I config the file using Putty in windows or do I need to config while in Pi, ie, log into the Pi ?
Thank you for your patience
Paul
It worked! Thanks. Did this once before, but apparently the trick is adding the SSH file.
Adding file ssh only enables SSH, it does not have any effect on configuration of feeder-id
It seems you were earlier configuring file piaware-config.txt using the feeder-id line starting with either piaware-config or sudo piaware-config. This made the configuration invalid.
The sudo piaware-config feeder-id xxxxx is used only if you are issuing this command from a terminal, such as PuTTY or Windows command prompt.
