Can you use PHP curl to get the api results as I already can get some information I need from Genames using the PHP Curl method .
if it is possible is it just a case of creating a url string with the parameters like &api_key= etc.
for example I use this like I said for genomes.org
http://api.geonames.org/findNearbyPlaceName?lat=47.3&lng=9&username=demo
// curl -X GET "https://aeroapi.flightaware.com/aeroapi/airports/KHOU" \
// -H "Accept: application/json; charset=UTF-8"
echo 'Process 01 - Getting Geonames Data ' . "<br>";
$ch = curl_init();
curl_setopt($ch, CURLOPT_POST, 1);
curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
$headers = [
'X GET "https://aeroapi.flightaware.com/aeroapi/airports/EGKK"',
'Accept: application/json; charset=UTF-8',
'x-apikey: api key hidden for this example'
curl_setopt($ch, CURLOPT_HTTPHEADER, $headers);
$server_output = curl_exec ($ch);
curl_close ($ch);
$aedata= json_decode($server_output, true);
var_dump($aedata);
when I ran this the var_dump returned NULL. no Curl errors reported ?
after some trial and error and using the documentation TRY IT and looking at the CURL schema I finally got it to work
$url = "https://aeroapi.flightaware.com/aeroapi/airports/EGKK";
$curl = curl_init($url);
curl_setopt($curl, CURLOPT_URL, $url);
curl_setopt($curl, CURLOPT_RETURNTRANSFER, **true**);
$headers = array(
"Accept: application/json; charset=UTF-8",
"x-apikey: hidden for this message purposes",
curl_setopt($curl, CURLOPT_HTTPHEADER, $headers);
//for debug only!
curl_setopt($curl, CURLOPT_SSL_VERIFYHOST, **false**);
curl_setopt($curl, CURLOPT_SSL_VERIFYPEER, **false**);
$resp = curl_exec($curl);
curl_close($curl);
var_dump($resp);
to which I got the data
string(405) "{"airport_code":"EGKK","alternate_ident":"LGW","code_icao":"EGKK","code_iata":"LGW","code_lid":null,"name":"London Gatwick","type":"Airport","elevation":196,"city":"London","state":"England","longitude":-0.190278,"latitude":51.148056,"timezone":"Europe/London","country_code":"GB","wiki_url":"https://en.wikipedia.org/wiki/Gatwick_Airport","airport_flights_url":"/airports/EGKK/flights","alternatives":[]}"
