**I tried to create performance numbers for the TR-182 after finding only the data for the normally aspirated R-182 in your database.
But the email address, “performance@flightaware.com” bounced back as undeliverable when I attached the performance section pdf per your instructions, and the program hangs up and will not accept cruise information for manually entered profile.
So how can I get you the performance numbers to upload for the TR-182? It would be nice to have accurate numbers in Flight Aware. Thanks,
I have added the following performance profiles for you:
Normal Climb - 95kias
Cruise at all altitudes (2 to 20k) for 2400 RPM and 25 MP
Cruise at all altitudes (2 to 20k) for 2400 RPM and 23 MP
Cruise at all altitudes (2 to 20k) for 2400 RPM and 21 MP
Cruise at all altitudes (2 to 20k) for 2400 RPM and 19 MP
I have set up the tables, but not included the data for the following performance profiles for you. If you want to use them, you will need to complete the data from the performance specs. If not, you can delete them or simply not choose when when setting up a flight plan:
Cruise at all altitudes (2 to 20k) for 2300 RPM and 25 MP
Cruise at all altitudes (2 to 20k) for 2300 RPM and 23 MP
Cruise at all altitudes (2 to 20k) for 2300 RPM and 21 MP
Cruise at all altitudes (2 to 20k) for 2300 RPM and 19 MP
Cruise at all altitudes (2 to 20k) for 2200 RPM and 25 MP
Cruise at all altitudes (2 to 20k) for 2200 RPM and 23 MP
Cruise at all altitudes (2 to 20k) for 2200 RPM and 21 MP
Cruise at all altitudes (2 to 20k) for 2200 RPM and 19 MP
Cruise at all altitudes (2 to 20k) for 2100 RPM and 25 MP
Cruise at all altitudes (2 to 20k) for 2100 RPM and 23 MP
Cruise at all altitudes (2 to 20k) for 2100 RPM and 21 MP
Cruise at all altitudes (2 to 20k) for 2100 RPM and 19 MP
Cruise at all altitudes (2 to 20k) for 2100 RPM and 17 MP
