Performance between Raspberry Pi's
I cloned the SSD to SD for the pi4…
When I first started it, it appeared to be better.
I then switched back to the pi3 as I had changed from individual 1ft extension cables to a usb hub for the radios so I wanted to see if that changed as well.
When I switched back to the pi4 it was mis-behaving again… Low range, poor network speeds…
And on top of that, it was not recognizing the UAT radio… (dump978-fa closing with error code 1)
So… not sure what to think… perhaps it was too close to the pi3’s SSD this last time? (I thought it was off, but ???)
Hardware issue?
Software issue?
Power supply issue? (I said I was using the official RPI one… I do have one, but its not on that Pi. Its from pishop.us. says is 5.1v, 3.0amp…
So switch the supplies and test it.
Yep switch supplies and test… power supplies can go bad over time… even if official ones…
