Is there any (relatively easy) way to report/record a peak value for number of aircraft tracked during a given period?
Looking at my local SkyAware map right now, I can see that I am tracking 65 aircraft. A few minutes ago it was 72. I think I have seen upper 80s a couple of times. But as far as I can tell, the only way to know the highest number I have tracked would be to have been looking at that page at the moment it was happening.
Thanks, I have that - and I’m not sure what more I was looking for. I think I remember that the graphs data gets “smoothed” over time, so I didn’t know for sure that it was showing the actual peak.
I suppose I could try to remember to look at it each day at 0:00GMT and manually record the peak value from the chart for the previous 24 hours. Or something like that.
I should also add that I can’t seem to use Graphs1090 with my FlightFeeder978, so I am probably limited to some kind of screen scraping to get the same kind of info from that one.
Yes, but I don’t have ssh access to my FlightFeeder978 - Flightaware has it locked down. If I were to build my own feeder for 978 I could definitely install the graphs app, but there’s no point in doing that since they were kind enough to provide one to me.
Find that section in /etc/collectd/collectd.conf and remove the # for 978, change the URL to point to the flightfeeder.
The restart the collectd service using sudo systemctl restart.
Note that there is no true maxima graph for 978 like there is for 1090.
