Pawer child killed
Hi Guys and Girls,
I’ve received my USB dongle today, at this time i’m trying to get Piaware running, but it’s giving me a Child Killed message…
Has anyone got a clue what this causes?
04/08/2015 21:09:08 ****************************************************
04/08/2015 21:09:08 piaware version 1.20 is running, process ID 2182
04/08/2015 21:09:08 your system info is: Linux hz-steppingstone 3.18.7+ #755 PREEMPT Thu Feb 12 17:14:31 GMT 2015 armv6l GNU/Linux
04/08/2015 21:09:08 connecting to FlightAware eyes.flightaware.com/1200
04/08/2015 21:09:48 got 'couldn't open socket: no such device or address (Temporary failure in name resolution)' to adept server at eyes.flightaware.com/1200, will try again soon...
04/08/2015 21:10:13 ADS-B data program 'dump1090' is listening on port 30005, so far so good
04/08/2015 21:10:13 i see dump1090 serving on port 10001
04/08/2015 21:10:13 connecting to dump1090 on port 10001...
04/08/2015 21:10:13 piaware is connected to dump1090 on port 10001
04/08/2015 21:10:14 dump1090 is listening for connections on FA-style port 10001
04/08/2015 21:11:08 0 msgs recv'd from dump1090; 0 msgs sent to FlightAware
04/08/2015 21:11:08 connecting to FlightAware 70.42.6.203/1200
04/08/2015 21:11:09 FlightAware server SSL certificate validated
04/08/2015 21:11:09 encrypted session established with FlightAware
child killed: write on pipe with no readers
    while executing
"close $fp"
    (procedure "get_default_gateway_interface_and_ip" line 13)
    invoked from within
"get_default_gateway_interface_and_ip gateway iface ip"
    (object "::adept" method "::fa_adept::AdeptClient::login" body line 31)
    invoked from within
"login"
    (object "::adept" method "::fa_adept::AdeptClient::connect" body line 59)
    invoked from within
"::adept connect"
    ("after" script)
Thanks and kind regards,
Patrick Lieftink
Is your Pi definitely online and have working DNS?
Well, it’s working now, i’ve set the DNS servers to the DNS Servers of my ISP, but i get the same messages.
Should I be worried…?
04/09/2015 06:15:45 ****************************************************
04/09/2015 06:15:45 piaware version 1.20 is running, process ID 2178
04/09/2015 06:15:45 your system info is: Linux hz-steppingstone 3.18.7+ #755 PRE        EMPT Thu Feb 12 17:14:31 GMT 2015 armv6l GNU/Linux
04/09/2015 06:15:45 connecting to FlightAware eyes.flightaware.com/1200
04/09/2015 06:15:47 FlightAware server SSL certificate validated
04/09/2015 06:15:47 encrypted session established with FlightAware
04/09/2015 06:15:47 autoUpdate in adept config is enabled, allowing update
04/09/2015 06:15:47 manualUpdate in adept config is enabled, allowing update
04/09/2015 06:15:48 ADS-B data program 'dump1090' is listening on port 30005, so        far so good
04/09/2015 06:15:48 i see dump1090 serving on port 10001
04/09/2015 06:15:48 connecting to dump1090 on port 10001...
04/09/2015 06:15:48 piaware is connected to dump1090 on port 10001
04/09/2015 06:15:48 dump1090 is listening for connections on FA-style port 10001
04/09/2015 06:15:48 piaware received a message from the ADS-B source!
04/09/2015 06:15:48 logged in to FlightAware as user RedFoxie
04/09/2015 06:15:58 piaware has successfully sent several msgs to FlightAware!
04/09/2015 06:16:18 18 msgs recv'd from dump1090; 17 msgs sent to FlightAware
    while executing
"close $fp"
    invoked from within
    (procedure "construct_health_array" line 16)
    invoked from within
"construct_health_array row"
    (procedure "periodically_send_health_information" line 8)
    invoked from within
    ("after" script)
04/09/2015 06:16:46 server is sending alive messages; we will expect them
    while executing
"close $fp"
    invoked from within
    invoked from within
    invoked from within
    ("after" script)
04/09/2015 06:22:58 295 msgs recv'd from dump1090 (277 in last 7m); 294 msgs sent to FlightAware
    while executing
"close $fp"
    invoked from within
    invoked from within
    invoked from within
    ("after" script)
04/09/2015 06:27:58 440 msgs recv'd from dump1090 (145 in last 5m); 439 msgs sent to FlightAware
    while executing
"close $fp"
    invoked from within
    invoked from within
    invoked from within
    ("after" script)
04/09/2015 06:32:58 628 msgs recv'd from dump1090 (188 in last 5m); 627 msgs sent to FlightAware
    while executing
"close $fp"
    invoked from within
    invoked from within
    invoked from within
    ("after" script)
04/09/2015 06:37:58 790 msgs recv'd from dump1090 (162 in last 5m); 789 msgs sent to FlightAware
Update: I’ve figured out that this messages are caused by the Quagga daemon, which is at the same Pi…
When i disable that daemon temporary the error’s are gone :slight_smile:
Quagga is for dynamic routing, and provides connectivity to my internal network by a OpenVPN Connection
04/09/2015 06:42:58 913 msgs recv'd from dump1090 (123 in last 5m); 912 msgs sent to FlightAware
04/09/2015 06:46:23 960 msgs recv'd from dump1090 (47 in last 3m); 959 msgs sent to FlightAware
04/09/2015 06:51:18 1107 msgs recv'd from dump1090 (147 in last 5m); 1106 msgs sent to FlightAware
04/09/2015 06:56:18 1354 msgs recv'd from dump1090 (247 in last 5m); 1353 msgs sent to FlightAware
root@hz-steppingstone:~# /etc/init.d/quagga start
Loading capability module if not yet done.
Starting Quagga daemons (prio:10): zebra bgpd2015/04/09 09:47:54 BGP: socket: Address family not supported by protocol
Starting Quagga monitor daemon: watchquagga.
root@hz-steppingstone:~# tail -f /tmp/piaware.out
04/09/2015 07:01:18 1564 msgs recv'd from dump1090 (210 in last 5m); 1563 msgs sent to FlightAware
04/09/2015 07:06:18 1801 msgs recv'd from dump1090 (237 in last 5m); 1800 msgs sent to FlightAware
04/09/2015 07:11:18 1955 msgs recv'd from dump1090 (154 in last 5m); 1954 msgs sent to FlightAware
04/09/2015 07:16:18 2067 msgs recv'd from dump1090 (112 in last 5m); 2066 msgs sent to FlightAware
04/09/2015 07:21:18 2202 msgs recv'd from dump1090 (135 in last 5m); 2201 msgs sent to FlightAware
04/09/2015 07:26:18 2367 msgs recv'd from dump1090 (165 in last 5m); 2366 msgs sent to FlightAware
04/09/2015 07:31:18 2517 msgs recv'd from dump1090 (150 in last 5m); 2516 msgs sent to FlightAware
04/09/2015 07:36:18 2672 msgs recv'd from dump1090 (155 in last 5m); 2671 msgs sent to FlightAware
04/09/2015 07:41:18 2872 msgs recv'd from dump1090 (200 in last 5m); 2871 msgs sent to FlightAware
04/09/2015 07:46:18 3106 msgs recv'd from dump1090 (234 in last 5m); 3105 msgs sent to FlightAware
    while executing
"close $fp"
    invoked from within
    invoked from within
    invoked from within
    ("after" script)
04/09/2015 07:53:18 3428 msgs recv'd from dump1090 (322 in last 7m); 3427 msgs sent to FlightAware
