[OUTDATED] Howto Install Piaware 3.8.1 on 64 bit Raspberry Pi OS (Raspbian) / Pi4
Radarbox24 arm64 feeder
Radarbox24 has now made available their rbfeeder_arm64 for 64-bit Raspbian OS. It can be installed by the same bash-script as used for 32-bit Raspbian OS (apt detects that the OS is arm64, and installs the package of rbfeeder & dependencies with arm64 architecture).
sudo bash -c "$(wget -O - http://apt.rb24.com/inst_rbfeeder.sh)"
If you already have a feeder key
sudo rbfeeder --setkey ‹your sharing key›
sudo systemctl restart rbfeeder
If you don’t have a sharing key, a new one will be created automatically when you connect to the RadarBox servers the first time. Go to claims page and claim your station.
https://www.radarbox.com/raspberry-pi/claim
MLAT
The 64-bit mlat-client is not yet available in Radarbox24 repository, hence attempt to install it by sudo apt install mlat-client will fail.
Install 64-bit mlat-client package available at my Github site by following commands:
wget https://github.com/abcd567a/mlat-client-package/releases/download/v1/mlat-client_0.2.11_BUSTER_arm64.deb
sudo dpkg -i mlat-client_0.2.11_BUSTER_arm64.deb
Configure mlat
sudo nano /etc/rbfeeder.ini
In [client] section add three lines with your latitude, longitude and altitude above sea level (in meters)
lat=xx.xxxx
lon=yy.yyyy
alt=zzz
Scroll down till you see this:
[mlat]
autostart_mlat=false
Replace “false” by “true”, so it becomes like this:
[mlat]
autostart_mlat=true
Save file (Ctrl+O) and close (Ctrl+X)
Restart rbfeeder
sudo systemmctl restart rbfeeder
