I will post an update when it’s installed… ty
Make sure you order the dark-blue filter. There are two types of Flightaware fliters.
(1) For Europe: Dark-blue, Band Pass Signal Filter,1090 MHz ONLY
(2) For North America: Light-blue Band Pass Signal Filter, DUAL 978-1090 MHz
(1) Your graph shows that your minimum gain is set to 33 by adaptive gain control. Messages > -3 dBFS (1.1% of messages) gives you a margin to increase adaptive-min-gain from 33 to 36 or even 39:
sudo piaware-config adaptive-min-gain 39
sudo reboot
(2) Can you please post your max range graph?
I’ll make that gain change and check in later.
Here’s a 48 hour range graph.
Jay
confirm dark blue 1090mhz one ordered. ty abcd
Here’s a fresh 48 hour message rate graph…
And a range graph…
And a gain graph…
Is my red area still a bit light?
Thanks,
Jay
2.1% is good
EDIT:
You are still below 3%.
Try increasing minimum gain from 39 to 42
sudo piaware-config adaptive-min-gain 42
sudo reboot
dark blue filter installed 24 hours ago. posting 48 hour graphs so there’s a comparison. max range increased from 200 to 215… 24 hour 3dbfs percentage is down 2.1%. can you see anything else or have any recommendations.? TIA
(1) What is the make of your Antenna and Coax cable? You only mentioned “60 cm” antenna in an earlier post. Is it Flightaware antenna, or another make which looks similar to Flightaware?
(2) Can you please post the current screenshot like the one below which you have posted few days earlier?
the antenna and 1m RG-58 cable were from pi hut - same place that supplied the flightaware Pro stick plus and filter. don’t think the antenna is branded. flightaware antenna not available in the uk
would it be worth investing in RG-142 cable?
here’s the current tar1090 tracks
would this antenna have been a better bet. its similar money… but made by an enthusiast…
With coax being only 1m length, quality of coax does not matter much.
No idea about this antenna, may be good, may be lousy.
Many well experienced forum members (@wiedehopf , @foxhunter, and @caius)have recommende vinnant antenna.
Hi, I had that antenna and it broke letting in water, go with these instead E-SHOP (vinnant.sk)
