Can somebody enlighten me what information and help can be gathered from the number of tracks seen?
There seem to be no direct relation to the aircrafts seen. Today i’ve received two spikes which are not related to increased aircraft traffic.
I understand on a reboot or restart of dump that the number is going up because the tracks must be read again.
But this time i did not do anything, the device was running all the time.
Notice how the shape of the green graph is similar to the shape of the red graph.
The red graph is essentially noise, so … the variation in the green graph is mostly that same noise.
It might be useful to plot “unique tracks” - “tracks with single message”.
nb: while it is generally true that you’d expect to see more aircraft when you see more tracks, it’s not strictly true, since one is measuring the density of aircraft in your coverage while the other is measuring the rate that aircraft pass through your coverage. A change in average aircraft speed or a change in the distribution of aircraft can change the relationship between those.
tracks: statistics on aircraft tracks. Each track represents a unique aircraft and persists for up to 5 minutes after the last message from the aircraft is heard. If messages from the same aircraft are subsequently heard after the 5 minute period, this will be counted as a new track.
Look at it as the number of aircraft coming into range per hour, whether that is newly arriving in your receiver range or coming out from behind an obstruction after a gap of at least 5 minutes.
It’s not necessarily a useful metric for assessing receiver performance since the figure changes so much with aircraft behaviour - a steady stream of aircraft arriving and landing that you can see continuously might show a similar number of tracks to only a few aircraft flying around and going in and out of coverage.
It’s a figure that is going to be fairly unique to your location and receiver set up, since things like obstructions will affect it quite a bit.
Old thread, sorry: but seeing lots of tracks today (rarely do I see >800/hour) but number of aircraft not especially high. Wonder if there is a bit of Tropo about, pressure seems to be building.
What I have seen is there can be huge spikes in the ADS-B Tracks Seen graph. What happens is 30 to 40 TIS-B detections occur practically instantaneously, all at essentially one location. They are at LAX in my case. Since it’s Tracks/Hour (a rate) it’s a large spike. It would be nice if TIS-B detections could be completely filtered out.
