HI There. 2 issues :
I am running pfclient and I see aircrafts.
pfclient is configured to echo on port 30054 its data coming from the 1090-puck (SBS3 format I think)
fr24feeder connects to pfclient without issue on port 30054 using SBS3 format
Planeplotter connects to pfclient on port 30054 without issue using SBS3 format
First issue :
However, PiAware DOES see msgs, but does not send them to flightaware.
“May 1 01:08:48 raspberrypi piaware[1983]: ADS-B data program ‘pfclient’ is listening on port 30054, so far so good
May 1 01:08:48 raspberrypi piaware[1983]: Starting faup1090: /usr/lib/piaware/helpers/faup1090 --net-bo-ipaddr 127.0.0.1 --net-bo-port 30054 --stdout --lat 0.000 --lon 0.000
May 1 01:08:48 raspberrypi piaware[1983]: Started faup1090 (pid 3131) to connect to pfclient
May 1 01:13:20 raspberrypi piaware[1983]: 40 msgs recv’d from pfclient (7 in last 5m); 0 msgs sent to FlightAware”
Second Issue :
I am regularly getting this message :
May 1 00:47:46 raspberrypi piaware[1983]: Receiver location changed, restarting faup1090
May 1 00:47:47 raspberrypi piaware[1983]: faup1090 exited with SIG SIGHUP
May 1 00:47:47 raspberrypi piaware[1983]: reconnecting to pfclient
What is wrong with my setup of PiAware ?
Some other log to show the setup:
Apr 30 21:43:29 raspberrypi piaware[7370]: piaware version 3.5.3 is running, process ID 7370
Apr 30 21:43:29 raspberrypi piaware[7370]: your system info is: Linux raspberrypi 4.9.35-v7+ #1014 SMP Fri
Apr 30 21:43:31 raspberrypi piaware[7370]: Connection with adept server at piaware.flightaware.com/1200 established
Apr 30 21:43:31 raspberrypi piaware[7370]: TLS handshake with adept server at piaware.flightaware.com/1200 completed
Apr 30 21:43:31 raspberrypi piaware[7370]: FlightAware server certificate validated
Apr 30 21:43:31 raspberrypi piaware[7370]: encrypted session established with FlightAware
