No UAT despite following instructions
My FlightAware Pro Stick (Orange model) is working fine.
But I am still not receiving any UAT aircraft.
As instructed, I changed “uat-receiver-type” to “sdr” and “receiver-type” to “none”.
Here is my config file.
Any idea what is wrong?
Thank you.
Alan Henney
henney@raspberrypi:/etc $ piaware-config -showall
#adaptive-burst no # using default value
#adaptive-dynamic-range yes # using default value
#adaptive-dynamic-range-target # no value set and no default value
#adaptive-max-gain # no value set and no default value
#adaptive-min-gain # no value set and no default value
#adept-serverhostspiaware.flightaware.com piaware.flightaware.com {206.253.80.196 206.253.80.197 206.253.80.198 206.253.80.199 206.253.80.200 206.253.80.201} {206.253.84.193 206.253.84.194 206.253.84.195 206.253.84.196 206.253.84.197 206.253.84.198}” # using default value
#adept-serverport 1200 # using default value
allow-auto-updates yes # value set at /etc/piaware.conf:7
#allow-ble-setup auto # using default value
#allow-dhcp-duid yes # using default value
allow-manual-updates yes # value set at /etc/piaware.conf:8
#allow-mlat yes # using default value
#allow-modeac yes # using default value
#beast-baudrate # no value set and no default value
#enable-firehose no # using default value
#feeder-id # no value set and no default value
#force-macaddress # no value set and no default value
#http-proxy-host # no value set and no default value
#http-proxy-password # no value set and no default value
#http-proxy-port # no value set and no default value
#http-proxy-user # no value set and no default value
#image-type # no value set and no default value
#manage-config no # using default value
#mlat-results yes # using default value
#mlat-results-anon yes # using default value
#mlat-results-format “beast,connect,localhost:30104 beast,listen,30105 ext_basestation,listen,30106” # using default value
#network-config-style buster # using default value
#priority # no value set and no default value
#radarcape-host # no value set and no default value
#receiver-host # no value set and no default value
#receiver-port 30005 # using default value
receiver-type none # value set at /etc/piaware.conf:12
#rfkill no # using default value
#rtlsdr-device-index 0 # using default value
#rtlsdr-gain max # using default value
#rtlsdr-ppm 0 # using default value
#slow-cpu auto # using default value
#uat-receiver-host # no value set and no default value
#uat-receiver-port 30978 # using default value
uat-receiver-type sdr # value set at /etc/piaware.conf:11
#uat-sdr-device driver=rtlsdr # using default value
#uat-sdr-gain max # using default value
#uat-sdr-ppm 0 # using default value
#use-gpsd yes # using default value
#wired-address # no value set and no default value
#wired-broadcast # no value set and no default value
#wired-gateway # no value set and no default value
#wired-nameservers “8.8.8.8 8.8.4.4” # using default value
#wired-netmask # no value set and no default value
#wired-network yes # using default value
#wired-type dhcp # using default value
#wireless-address # no value set and no default value
#wireless-broadcast # no value set and no default value
#wireless-country 00 # using default value
#wireless-gateway # no value set and no default value
#wireless-nameservers “8.8.8.8 8.8.4.4” # using default value
#wireless-netmask # no value set and no default value
#wireless-network no # using default value
#wireless-password # no value set and no default value
#wireless-ssid # no value set and no default value
#wireless-type dhcp # using default value
What base image are you using?
(Config being in /etc/piaware.conf implies a package install, not a PiAware sdcard image; for a package install, you’ll need to also ensure that dump978-fa is correctly installed/configured)
Thanks. I didn’t know that dump978-fa needed to be configured for UAT? It’s tracking the normal activity now, just not UAT.
Where do I find the dump978-fa config info?
Alan
The answer depends on the image you are using.
Please tell what image you are using, piaware SD card image, Raspberry Pi OS image, or something else?
