Hi,
My setup consists of RTL-SDR V4, RPI4B and a coaxial collinear antenna made using RF-10 cable.
The setup is running on Debian Bookworm 32-bit, Im using a dump1090-fa decoder.
This is my output of rtl_test :
Found 1 device(s):
0: RTLSDRBlog, Blog V4, SN: 00000001
Using device 0: Generic RTL2832U OEM
Found Rafael Micro R828D tuner
[R82XX] PLL not locked!
Sampling at 2048000 S/s.
Info: This tool will continuously read from the device, and report if
samples get lost. If you observe no further output, everything is fine.
Reading samples in async mode…
Allocating 15 zero-copy buffers
lost at least 64 bytes
Afer many tries with other decoders, and completely reinstalling the system multiple times the decoder is still showing no messages.
I have tested it using a windows rtl1090 decoder and it works fine.
Im attaching a sample:
I was trying to come to a solution by reading through forums, but I have no idea what can be wrong.
The RPI4B is powered by the original power supply, and the RTL-SDR is connected directly into a usb port (no extensions).
I have ran some voltage tests and they also came out okay, I have no idea what to blame anymore, please help :((….
