No ADSB Program Reporting Message
So I am puzzled. About 10 am it appears my pi with PiAware stopped reporting positions but it remains connected. I rebooted the device and did a hard reset. It came back up but now shows the MLAT red but the other two are green and connected yet nothing is being reported.
When I view the device I get an error type message that the device isn’t transmitting data. This device has been running with no issues or changes for over `140 days. What is going on with it?
depending on which decoder you are using select any of the following commands and post the output here
sudo systemctl status readsb
One might work, the other not,
This message states that no decoder is running. I assume dump1090 failed to start.
Another command to identify the issues is
journalctl -xe|grep dump1090-fa
(or readsb if this is in use)
Post the output here too
Also see this thread. Help! No aircraft suddenly
