FlightAware Discussions
NGINX Reverse Proxy & Base URL
I am using PiAware and I want to put it behind my NGINX reverse proxy server. Having the ability to change the base url would make the process easier.
Is there a location to change the base url on PiAware?
Has anyone setup NGINX to work with PiAware and do you have a config you could share?
Just check the config files in
/etc/lighttpd/conf-enabled/
And adjust as needed.
Then
service lighttpd force-reload
to restart lighttpd.
Not sure what exactly you want though.
I run PiAware behind a reverse proxy Apache server and have for years. What is the benefit of changing the base URL? I didn’t consider doing that but perhaps you could educate me in the advantages of doing that.
Thanks.
