Hi guys,
I have never posted on here as I am not an air traffic controller or avid aviation guy, but I thought this is something you should all be aware of. To summarize, like you may be aware from 2 years ago, the FAA again has plans to transfer several dozen weather observing stations from CWO to LAWRS. Some of you may already be LAWRS observers in addition to ACT specialists. Unlike 2 years ago, the FAA is “only” planning to initially transition 57 stations (out of approximately 140) around the US. If that’s not bad enough, I believe this is just a cover until the FAA can try to transfer all CWOs to LAWRS. They’re just using the divide and conquer method this time because they didn’t get their way last time.
If you don’t like what you are about to read, then please advise your ATC managers or associations you may belong to (ie, AOPA, AAAE, etc.) that it is a bad idea. Many of them probably don’t even know about this transition plan yet, so feel free to show them it. The FAA plans to start soliciting ATC personnel starting in mid July, with some suggesting a possible changeover as early as October 1 of this year! However, it would be nice if they/you had a heads up. If the FAA gets enough pushback, I don’t believe it will happen. So that is where you guys can help. You may be surprised to find your site on the transition list at the end of the document. This document is official:
Thank You For Any Help,
skobie
Weather Observer
skobie
wxobservers.freeforums.net/threa … t-grouping
(you’ll have to click on the .pdf link: 05-15-2015 - potential cwo closings.pdf (138.62 KB) to see the proposal and list of potentially transferred CWO to LAWRS stations)
