Hi Fellas. I will use a help of any expert here to feed my data to FR4 from my newly receive flight feeder . Its up and running and i have installed antenna on my 2 story condo roof. I would to feed to FR4 too but this FA system is so restricted so not sure how can i feed to others . Please advise.
Thanks in advance. Tis hobby is so addictive. Also on side note i have 1090 and 978 running on Pi4 but that antennas are indoors. :).
You will need a separate device (does not need much power, even a Pi Zero should be fine) to run the FR24 feeder or whatever other software you want. You could use your Pi 4 for that. FlightFeeders provide a raw data stream on TCP port 30005 that has all the data they receive, you can point your separate device at that. Please don’t modify the FlightFeeder itself.
Sure . No i am not trying to modify. all i want to share to other aggregators. Would u mind please help to get those ssh prompt so i can add that in my pi4 .Thanks.
In case you want an easy setup, i’d recommend putting adsb.im on the pi4.
I don’t think the FA receiver you got does 978? Or does it?
In that case, remove the 1090 SDR from the pi4, keep the 978 setup.
In the adsb.im webinterface you’d go to Setup → SDR.
Set the 978 SDR as 978 so that works.
Then enter the IP of the FA receiver in the free text field to receive the 1090 data from it.
You can also modify your existing setup.
Getting data from 2 SDRs causes issues with MLAT so you can’t really keep that 1090.
But you can make the decoder running on the pi4 network only and get the data.
For example by using readsb as the decoder and specifying a net-connector.
But i don’t really spend time explaining the details of such configs anymore because it’s faster for me to point to adsb.im
Whichever way you go, good luck!
I’m fortunate to have reply from you buddy. I tried all your scipts on my pi4 . Solid work. Again not too smart here with ssh and those commands. I have pi4 seup with raspberry pi adsb distro . I have to go to adsb-feeder.local to access my interface. Somehow myltiple ssh from multiple pi my ssh confused and don’t let me login to root lol. Still learning. I have one more pi4 which i just bought from offer up lol. So addictive.
You have to change following two (2) lines of file fr24feed.ini
(1) Change receiver="avr-tcp"
to receiver="beast-tcp"
(2) Change host="127.0.0.1:30002"
to host=192.168.12.25:30005"
As I dont know local IP of your Flightfeeder, in above instructions I have used 192.168.12.25. Instead of 192.168.12.25 , use actual local IP of your Flightfeeder
Note:
Dont forget to
(1) save the file after editing
(2) Restart fr24feed by following command:
Perfect i can see same as your. but i got another problem. after making this flightaware feeder working my original feed stopped working lol on pi4. They got offline lol.
