***ok did my sudo piaware-config -user foxy647130 -password
it asked me to put in my password it took it fine,
Now I did rtl_test -t
found 1 device ( s ) :
0: Generic ,RTL2832, SN: 77771111153705700
using device o: generic RTL 2832U
kernel driver is active, or device is claimed by second instance of librtlsdr.
In the first case, please either detach or blacklist Ok here is what I need HELP with if I do the black list i get into another command
I do the three blacklist rtls then i have read save the black list file , Ok as shown above i was getting frustrated and went and looked at my live feed and it showed my 10.0.0.46:8080/ comes up and states page unreachable. I would love is some one could do a team viewer and look at my set up and tweak things for me. I have the new pi with hdmi hooked up and a NooElec dongle running on a usb powered hub and a wireless keyboard. If you want to do a team viewer my pc is clean***
What is the problem? You seem to be up and running, see: flightaware.com/adsb/stats/user/foxy647130
Getting frustrated comes with the territory, welcome aboard. You said that after the reboot, you got ‘page unreachable’. Take a look at your site noted above. Check the IP address- DHCP may have given you a new IP address- that should be in the info block visible to you. There should also be an option to check your output xxx.xxx.xxx.xxx:8080.
Disclaimer: not an expert Matt 15:14 applies. YMMV
[quote=“foxy647130”]
This is normal if dump1090 is running. You can only have one thing using the dongle at a time. If you try to start a second thing, you’ll see that error. To run rtl_test, you’ll first need to stop dump1090. (But if dump1090 is working, you probably don’t need to run rtl_test, it’s working!)[/quote]
