MLAT not sync'ing after migration
Thanks… checked the system and wasn’t seeing any USB errors. usbfs memory was set to 16 MB so I bumped it to 256 MB and restarted piaware and it still came back complaining of clock instability. I’m getting fairly convinced the single USB host controller can’t handle the timing needed.
Nah, AIS uses that little sample rate it’s not an issue i don’t think.
Hard to say what’s going on.
Very much doubt pyasyncore is the issue.
The critical part is between the decoder and the SDR.
mlat-client has nothing to do with that.
It’s not time critical.
(and the USB jitter is not an issue either as long as not data gets lost, just the count of the samples has to be uninterrupted)
I tried moving the adsb Airpsy Mini to a different port but with it being a USB 2.0 device it’s gets routed back to the same bus.
All the interrupts seem to be going to a single core.
As far as I can tell no data is being lost
I’m out of my element so if there is any other information I can supply just let me know. Greatly appreciate your patience.
Are the DragonOS Jammy Ubuntu 22.04 and DragonOS Resolute Ubuntu 26.04 running on identical machines? If not, then issue may be the machine (radio-2) itself. Do you have another machine to test DragonOS Resolute Ubuntu 26.04 on it?
No,.. they are not the same machine. BUT… while trying a bunch of different things that didn’t seem to work I thought I’d check the piaware web viewer to see how many planes were being picked up… and it showed some MLAT entries. And it’s been stable for about 3 hours now.
As best I can figure out when I moved the Airspy Mini from the powered USB hub to a USB 3.0 port on the laptop it started working. Keeping my fingers crossed that it holds up.
Thanks again for all the help, ideas, suggestions and patience.
Sep 24 19:25:18 radio2 piaware[727443]: mlat-client(727471): Server status: synchronized with 399 nearby receivers
:+1: :+1: :+1:
CONGRATULATIONS :slightly_smiling_face:
The log wouldn’t show that.
Sample data is not numbered so the decoder really can’t tell.
(well you can do stuff using per time but airspy_adsb doesn’t, also hard to detect if just a bit of data gets lost)
Thanks for all your help.
I let it run for about 24 hours and it seemed to be very stable. Today I started trying different connection points for the Airspy Mini. Short version of this is… if the powered USB hub was part of the equation then the unstable clock errors would show up. So that powered USB hub is no longer involved in the ADS-B data flow.
Interesting. I had the exact opposite experience. I needed a powered USB hub to make MLAT reliable.
I can only guess your issue may have been power related where in this case it seemed to be some sort of USB timing/prioritization issue between the powered hub and the laptop. This same powered hub worked fine on the previous laptop.
