Hi everyone,
Was using a pi zero, rtl-sdr.com V3 dongle for serving flight aware. Raspbian stretch.
Mlat kept dropping out (even though I am regularly synchronised with 600+ other receivers)
Thought it was CPU overload so moved set up to RPi 3B. Raspbian buster, CPU load way lower. CPU temp never over 42 degrees Celsius.
Mlat still randomly drops out.
USB issue? Can I do anything about it other than restarting, stopping dump 1090, switching on bias tee from command line, restarting dump 1090?
I have some shell scripting experience, so is it possible to write a script that detects the non synching in the logs and then does the restart process as described?
OK - already on latest kernel. dist-upgrade didn’t do anything at all.
Power supply check next. I know I’ve got two official power supplies (one new one for my pi4 ) but couldn’t swear about the third.
My co-ordinates are recorded to 5 decimal places, so I suspect that’s good enough.
On the pi-zero I think I put an entry into crontab that rebooted every 15 minutes, I think - it was a while ago - because the dongle was shutting down. Hmm - seeing a pattern…
Seems sensible. I think it’s a cheap cable and I have just bought a couple of significantly better ones which have a LOT more copper, one of which is only supplying power to a fan.
Time to have a swap around and see what works best.
Thanks for the suggestions.
The dongle is also supplying to the uputronics lna, which although isn’t a huge current draw might be a factor I suppose (especially if the USB extension lead is dodgy)
When I raised my antenna I added a 25 foot extension with a union and lost nearly 50% of my tracking numbers.When I lowered the antenna just enough to remove the extension the numbers came back up.
One other thing, when I first set up my system I let it choose it’s location. I would drop Mlat a lot. So I loaded an app on my phone and used it to get current location and then measured the height above ground. I then plugged those numbers into the configuration and Mlat works a lot better.
