Who can help?
two days ago my rasperry pi II restarted after power failure and then mlat no longer works for me !?
Everything is ok until the failure!
I have not changed anything
Here my log´s:
[2017-12-13 16:51 CET] ====== successful login from piaware 3.5.3 from ******** ======
[2017-12-13 16:51 CET] logged in to FlightAware as user hirntodhd
[2017-12-13 16:51 CET] my feeder ID is 48************************
[2017-12-13 16:51 CET] site statistics URL: https://flightaware.com/adsb/stats/user/hirntodhd#stats-11673
[2017-12-13 16:51 CET] multilateration data requested
[2017-12-13 16:51 CET] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 70.42.6.225:5007:1278846826
[2017-12-13 16:51 CET] mlat-client(5360): fa-mlat-client 0.2.10 starting up
[2017-12-13 16:51 CET] mlat-client(5360): Using UDP transport to 70.42.6.225 port 5007
[2017-12-13 16:51 CET] mlat-client(5360): Listening for Beast-format results connection on port 30105
[2017-12-13 16:51 CET] mlat-client(5360): Listening for Extended Basestation-format results connection on port 30106
[2017-12-13 16:51 CET] mlat-client(5360): Input connected to localhost:30005
[2017-12-13 16:51 CET] mlat-client(5360): Input format changed to BEAST, 12MHz clock
[2017-12-13 16:51 CET] mlat-client(5360): Beast-format results connection with ::1:30104: connection established
[2017-12-13 16:51 CET] mlat-client(5360): Accepted Extended Basestation-format results connection from ::ffff:*********:8523
[2017-12-13 16:52 CET] 243408 msgs recv’d from dump1090-fa (1696 in last 5m); 242935 msgs sent to FlightAware
[2017-12-13 16:57 CET] 245135 msgs recv’d from dump1090-fa (1727 in last 5m); 244662 msgs sent to FlightAware
[2017-12-13 17:02 CET] 246655 msgs recv’d from dump1090-fa (1520 in last 5m); 246182 msgs sent to FlightAware
[2017-12-13 17:06 CET] mlat-client(5360): Receiver status: connected
[2017-12-13 17:06 CET] mlat-client(5360): Server status: clock unstable
[2017-12-13 17:06 CET] mlat-client(5360): Receiver: 998.5 msg/s received 216.5 msg/s processed (22%)
pi@flight145:~ $ piaware-status
PiAware master process (piaware) is running with pid 485.
PiAware ADS-B client (faup1090) is running with pid 739.
PiAware mlat client (fa-mlat-client) is running with pid 5360.
Local ADS-B receiver (dump1090-fa) is running with pid 476.
dump1090-fa (pid 476) is listening for connections on port 30005.
