POSSIBLE REMEDY FOR V-STUB:
Add an external Filter between Dongle and V-Stub antenna.
With my V-Stub, I am using a Radarbox24 FlightStick (Green), which has a SAW filter chip between antenna SMA connector and front-end LNA / tuner chip R820T2. This is equivalent to adding an external filter to ProStick/ProStickPlus.
I am not sure as I have not checked it myself. I got this info from somewhere on web or in some forum where someone has opened the plastic cover of Radarbox 24’s green stick and physically found the SAW chip is connected between Antenna SMA and front-end LNA / Tuner.
Try to swap the Radarbox24 green dongle with another one (if you have a spare) to cover the (unlikely) case of defective SAW chip in that particular dongle.
Don’t know as I did not perform real-time sweeps. Will do it when find time, as I will have to first built both the spider and V-stub (the V-stub I have made got damaged)
Results are pretty dang close when looking at the ~300Mhz, ~700Mhz and ~1100Mhz (every ~400Mhz or so). Obviously tough to decipher some of it with the wider resolution, but that’s irrelevant for a basic confirmation of the sim. Of course the N1201SA gets a little wonky > about 1800Mhz or so no matter how they have it spec’d, but for the money and ease of use it’s nice to be able to confirm some things.
Both avenues illustrate that the design would have a predisposition to pickup those ~400Mhz frequency increments, but not many designs are truly resonant at only one frequency.
Seeing that does contribute to more confidence in the simulation. Be neat to see more as time goes by. The simulation gain plot sure is interesting, too bad we cant confirm that with cheap equipment as well.
Repeat comparison of V-stub Magmount vs FA antenna, using data of Sept 30, 2020 from Flightaware stats page. (Previous was using data of Sept 29, 2020) Results are consistant.
Both antennas in same window. The V-stub Magmount placed on metallic window sill, while FA antena hanging from a string besides it at 30 cm horizontal seperation
Not sure if that’s an absolute, but it does dump about 1dB/m (The high quality stuff), so 3m will effectively half the signal. There are better options of course for a test of this sort, especially if using different length cable.
RG174 is standard cable used with magmount wip supplied with generic dvbt, as well as independently sold “5dBi” coiled magmount. Normally the length of this cable is 1 m only.
However I purchased a magmount whip with 3m RG174 because of distance between window sill and PC. From this magmount, I unscrewed the “5dBi” whip, and installed DIY V-Stub whip.
To make both side-by-side setups as similar as possible, I replaced the 30cm RG316 pigtail between FA antenna and dongle by a 2m RG174 coax which I already had.
