Losing website connection
Every so often I will go to my page to look at stats or flights and some times it will not show any info, like the web server is not working! I can SSH into it with no issues! I looked at the debug commands on GitHub (wiedehopf/adsb-wiki) and the only log I could see producing an error was dump978-fa. I run both 978 & 1090.
Here is part of the log,
Feb 10 13:01:03 piaware dump978-fa[14281]: [::1]:38758: connection closed
Feb 10 13:01:03 piaware dump978-fa[14281]: Caught signal 15, exiting
Feb 10 13:01:03 piaware systemd[1]: Stopping dump978 ADS-B UAT receiver...
Feb 10 13:01:08 piaware dump978-fa[14281]: Abnormal exit
Feb 10 13:01:08 piaware systemd[1]: dump978-fa.service: Main process exited, code=exited, status=1/FAILURE
Feb 10 13:01:08 piaware systemd[1]: dump978-fa.service: Failed with result 'exit-code'.
Feb 10 13:01:08 piaware systemd[1]: Stopped dump978 ADS-B UAT receiver.
Feb 10 13:01:08 piaware systemd[1]: dump978-fa.service: Consumed 17min 37.448s CPU time.
Feb 10 13:01:08 piaware systemd[1]: Started dump978 ADS-B UAT receiver.
Feb 10 13:01:08 piaware dump978-fa[14723]: raw-port: listening for connections on 0.0.0.0:30978
Feb 10 13:01:08 piaware dump978-fa[14723]: raw-port: listening for connections on [::]:30978
Feb 10 13:01:08 piaware dump978-fa[14723]: json-port: listening for connections on 0.0.0.0:30979
Feb 10 13:01:08 piaware dump978-fa[14723]: json-port: listening for connections on [::]:30979
Feb 10 13:01:08 piaware dump978-fa[14723]: usb_claim_interface error -6
Feb 10 13:01:09 piaware dump978-fa[14723]: Found Rafael Micro R820T tuner
Feb 10 13:01:09 piaware dump978-fa[14723]: Exact sample rate is: 2083333.135571 Hz
Feb 10 13:01:09 piaware dump978-fa[14723]: [R82XX] PLL not locked!
Feb 10 13:01:10 piaware dump978-fa[14723]: SoapySDR: using maximum manual gain 49.6 dB
Feb 10 13:01:10 piaware dump978-fa[14723]: SoapySDR: using stream setting buffsize=262144
Feb 10 13:01:10 piaware dump978-fa[14723]: Allocating 15 zero-copy buffers
Feb 10 13:01:13 piaware dump978-fa[14723]: [::]:30978: accepted a connection from [::1]:38762
Feb 10 13:01:38 piaware dump978-fa[14723]: [::]:30978: accepted a connection from [::1]:38764
Feb 10 18:22:49 piaware dump978-fa[14723]: [::1]:38762: connection closed
Feb 10 18:22:54 piaware dump978-fa[14723]: [::]:30978: accepted a connection from [::1]:38774
Feb 10 20:52:55 piaware dump978-fa[14723]: [::1]:38774: connection closed
Feb 10 20:52:57 piaware dump978-fa[14723]: Caught signal 15, exiting
Feb 10 20:52:57 piaware systemd[1]: Stopping dump978 ADS-B UAT receiver...
Feb 10 20:53:02 piaware dump978-fa[14723]: Abnormal exit
Feb 10 20:53:02 piaware systemd[1]: dump978-fa.service: Main process exited, code=exited, status=1/FAILURE
Feb 10 20:53:02 piaware systemd[1]: dump978-fa.service: Failed with result 'exit-code'.
Feb 10 20:53:02 piaware systemd[1]: Stopped dump978 ADS-B UAT receiver.
Feb 10 20:53:02 piaware systemd[1]: dump978-fa.service: Consumed 2h 7min 19.884s CPU time.
Feb 10 20:53:02 piaware systemd[1]: Started dump978 ADS-B UAT receiver.
Feb 10 20:53:02 piaware dump978-fa[17953]: raw-port: listening for connections on 0.0.0.0:30978
Feb 10 20:53:02 piaware dump978-fa[17953]: raw-port: listening for connections on [::]:30978
Feb 10 20:53:02 piaware dump978-fa[17953]: json-port: listening for connections on 0.0.0.0:30979
Feb 10 20:53:02 piaware dump978-fa[17953]: json-port: listening for connections on [::]:30979
Feb 10 20:53:02 piaware dump978-fa[17953]: usb_claim_interface error -6
Feb 10 20:53:02 piaware dump978-fa[17953]: Found Rafael Micro R820T tuner
Feb 10 20:53:03 piaware dump978-fa[17953]: Found Rafael Micro R820T tuner
Feb 10 20:53:03 piaware dump978-fa[17953]: Exact sample rate is: 2083333.135571 Hz
Feb 10 20:53:03 piaware dump978-fa[17953]: [R82XX] PLL not locked!
Feb 10 20:53:03 piaware dump978-fa[17953]: SoapySDR: using maximum manual gain 49.6 dB
Feb 10 20:53:03 piaware dump978-fa[17953]: SoapySDR: using stream setting buffsize=262144
Feb 10 20:53:03 piaware dump978-fa[17953]: Allocating 15 zero-copy buffers
Feb 10 20:53:07 piaware dump978-fa[17953]: [::]:30978: accepted a connection from [::1]:38784
Feb 10 20:53:32 piaware dump978-fa[17953]: [::]:30978: accepted a connection from [::1]:38786
Thing is, looking at this time is wrong! It is ahead but yet my server and 1090 logs are correct! Also on my flightaware page it is correct time! When I look at my stats page, it is also showing the date as tomorrow for aircraft reported.
Also checked for voltage issues, none exist.
Log timestamps are in UTC.
please be more specific; provide a screenshot if you can.
It can be that your 978 stick is either faulty or not connected properly.
I had the situation with my 1090 stick some months ago and identified that the USB connect was not perfect. After squeezing a bit the connector and attached it again, it was working.
You could also try a different USB port.
Are you using an extension USB cable? Can also be the root cause.
