Among my favorites are auto logging FM DX to RabbitEars, general SWLing, feeding PSKReporter and WSPRnet, receiving NOAA and other weather sats… and the list goes on.
A new source of ideas is exploring the 100+ modes decoded by OnAir.
Some people disparage the RTL-SDR. While its performance does not compare to more expensive SDRs I consider it one of the best values out there.
Thank you, Dxista, for all these great suggestions!
To be honest, I’ve mostly focused on ADS-B, VDL2, HFDL, and basic satellite reception so far, so things like FM DXing with RabbitEars or exploring 100+ modes with OnAir are completely new territory for me.
OnAir in particular sounds like a fascinating rabbit hole to dive into. And I completely agree with you on the RTL-SDR—for the price, its value and versatility are unmatched!
Inspired by your suggestion, I came up with a fun new project for my V4: “Building a Headless, FFT-Based Meteor Echo Monitor with Python and RTL-SDR Blog V4.”
Instead of traditional time-domain power monitoring which gave me endless false positives from noise, I wrote a lightweight Python script that monitors the FFT stream for real-time SNR spikes on target frequencies.
I’m still struggling a bit with fine-tuning the detection threshold and parameters to completely filter out noise, but it’s now running as a systemd service, aiming to catch clean meteor echo bursts without cluttering my logs!
Appreciate the inspiration—it gave my idle V4 a whole new life!
Following your hints and some further testing, I’ve successfully sorted out the threshold and noise issues.
By measuring the actual noise floor (around 1422 RMS) and locking in a manual tuner gain (36.4 dB) on my RTL-SDR Blog V4, I calibrated the detection threshold to 3500.
Now, the setup is fully operational with:
A Python ring-buffer script to capture pre- and post-trigger audio.
Automatic WAV saving into ~/hro_captures/ whenever a clean meteor echo spikes.
A robust 24/7 background operation running seamlessly as a systemd service.
My idle V4 is officially a fully automated, headless HRO monitoring station now. Thanks again for the great inspiration!
Targeting the 7 kW J-WAVE broadcast from the Tokyo Skytree, I’m all set here in Hirosaki, quietly waiting for gifts from shooting stars…
Exactly! That completely removes the hassle of building dependencies and dealing with complicated setups that traditional SDR tools usually require.
It drastically lowers the barrier to entry! Thanks for sharing such a cool project, Dxista!
After further testing, it turned out my previous setup had a frequency shifting issue with rtl_fm (it was auto-resampling and drifting away from the exact 81.3 MHz).
To fix this, I pivoted the approach:
Switched from rtl_fm to rtl_sdr to stream raw I/Q data directly.
Implemented a Python script that reads raw I/Q samples and performs precise FFT-based monitoring.
Successfully locked in the exact 81.3 MHz frequency without any automatic tuning drift.
The revised 24/7 background service is now up and running smoothly. Back to observation and observation logging!
