Login administratively disabled by FlightAware staff
I have to sites. One ist working normaly but the second have a problem. It does not report any data for the last 22 Days. Unfortunately i received now email, maybe because the pi is online but not reporting.
I found out that the login was disabled. So, what is wrong or the problem. What i’m supposed to do?
T
pi@Flighttrack:~ $ sudo systemctl status piaware -l
Loaded: loaded (/lib/systemd/system/piaware.service; enabled)
Active: failed (Result: exit-code) since Sa 2018-01-06 12:11:56 CET; 15min ag o
Process: 593 ExecStart=/usr/bin/piaware -p %t/piaware/piaware.pid -plainlog -s tatusfile %t/piaware/status.json (code=exited, status=4)
Main PID: 593 (code=exited, status=4)
Jan 06 12:11:55 Flighttrack piaware[593]: Starting faup1090: /usr/lib/piaware/he lpers/faup1090 –
Jan 06 12:11:56 Flighttrack piaware[593]: LOGIN FAILED: status ‘error’: reason ’ login administratively disabled by FlightAware staff due to a problem with the s ite’
Jan 06 12:11:56 Flighttrack piaware[593]: please correct this, possibly using pi aware-config
Jan 06 12:11:56 Flighttrack piaware[593]: to set valid Flightaware user name and password.
Jan 06 12:11:56 Flighttrack piaware[593]: piaware will now exit.
Jan 06 12:11:56 Flighttrack piaware[593]: You can start it up again using ‘sudo service piaware start’
Regards
Eike
You were contacted via e-mail by our staff about this on December 15. Your site appeared to be backfeeding MLAT results as ADS-B. This is not allowed. Please respond to the e-mail from our support staff or contact us directly at adsbsupport@flightaware.com if you need assistance with fixing your PiAware configuration.
