Run: IP_address/dump1090-fa/data/stats.json
“latest”:{“start”:1500630518.7,“end”:1500630518.7,“local”:{“samples_processed”:0,“samples_dropped”:0,“modeac”:0,“modes”:0,“bad”:0,“unknown_icao”:0,“accepted”:[0,0],“strong_signals”:0},“remote”:{“modeac”:0,“modes”:0,“bad”:0,“unknown_icao”:0,“accepted”:[0,0]},“cpr”:{“surface”:0,“airborne”:0,“global_ok”:0,“global_bad”:0,“global_range”:0,“global_speed”:0,“global_skipped”:0,“local_ok”:0,“local_aircraft_relative”:0,“local_receiver_relative”:0,“local_skipped”:0,“local_range”:0,“local_speed”:0,“filtered”:0},“altitude_suppressed”:0,“cpu”:{“demod”:0,“reader”:0,“background”:0},“tracks”:{“all”:0,“single_message”:0},“messages”:0},
“last1min”:{“start”:1500630458.7,“end”:1500630518.7,“local”:{“samples_processed”:143917056,“samples_dropped”:0,“modeac”:0,“modes”:942303,“bad”:539225,“unknown_icao”:309811,“accepted”:[87991,5276],“signal”:-7.5,“noise”:-16.1,“peak_signal”:-0.9,“strong_signals”:4885},“remote”:{“modeac”:0,“modes”:0,“bad”:0,“unknown_icao”:0,“accepted”:[0,0]},“cpr”:{“surface”:0,“airborne”:4418,“global_ok”:3955,“global_bad”:1,“global_range”:1,“global_speed”:0,“global_skipped”:10,“local_ok”:394,“local_aircraft_relative”:0,“local_receiver_relative”:0,“local_skipped”:68,“local_range”:0,“local_speed”:0,“filtered”:0},“altitude_suppressed”:0,“cpu”:{“demod”:11386,“reader”:4539,“background”:989},“tracks”:{“all”:12,“single_message”:0},“messages”:93267},
“last5min”:{“start”:1500630218.7,“end”:1500630518.7,“local”:{“samples_processed”:719978496,“samples_dropped”:0,“modeac”:0,“modes”:4704030,“bad”:2689937,“unknown_icao”:1542973,“accepted”:[444115,27005],“signal”:-7.3,“noise”:-16.0,“peak_signal”:-0.9,“strong_signals”:26993},“remote”:{“modeac”:0,“modes”:0,“bad”:0,“unknown_icao”:0,“accepted”:[0,0]},“cpr”:{“surface”:0,“airborne”:23116,“global_ok”:20883,“global_bad”:2,“global_range”:1,“global_speed”:1,“global_skipped”:48,“local_ok”:1952,“local_aircraft_relative”:0,“local_receiver_relative”:0,“local_skipped”:279,“local_range”:0,“local_speed”:0,“filtered”:0},“altitude_suppressed”:0,“cpu”:{“demod”:57132,“reader”:22831,“background”:4884},“tracks”:{“all”:61,“single_message”:12},“messages”:471120},
“last15min”:{“start”:1500629618.7,“end”:1500630518.7,“local”:{“samples_processed”:2159935488,“samples_dropped”:0,“modeac”:0,“modes”:13997189,“bad”:7986867,“unknown_icao”:4568387,“accepted”:[1360499,81436],“signal”:-7.0,“noise”:-15.6,“peak_signal”:-0.7,“strong_signals”:100065},“remote”:{“modeac”:0,“modes”:0,“bad”:0,“unknown_icao”:0,“accepted”:[0,0]},“cpr”:{“surface”:2,“airborne”:74773,“global_ok”:68698,“global_bad”:9,“global_range”:1,“global_speed”:8,“global_skipped”:145,“local_ok”:5333,“local_aircraft_relative”:0,“local_receiver_relative”:0,“local_skipped”:735,“local_range”:0,“local_speed”:3,“filtered”:0},“altitude_suppressed”:0,“cpu”:{“demod”:170697,“reader”:69154,“background”:14507},“tracks”:{“all”:163,“single_message”:29},“messages”:1441935},
“total”:{“start”:1500303458.6,“end”:1500630518.7,“local”:{“samples_processed”:784912351232,“samples_dropped”:0,“modeac”:0,“modes”:505462661,“bad”:2762259291,“unknown_icao”:1627194959,“accepted”:[390057044,20918663],“signal”:-7.5,“noise”:-17.6,“peak_signal”:-0.3,“strong_signals”:25497362},“remote”:{“modeac”:0,“modes”:2476902,“bad”:0,“unknown_icao”:0,“accepted”:[2476902,0]},“cpr”:{“surface”:5220,“airborne”:22906472,“global_ok”:21442594,“global_bad”:9212,“global_range”:6811,“global_speed”:336,“global_skipped”:42349,“local_ok”:1230825,“local_aircraft_relative”:0,“local_receiver_relative”:0,“local_skipped”:229061,“local_range”:77,“local_speed”:3636,“filtered”:41427},“altitude_suppressed”:0,“cpu”:{“demod”:56372567,“reader”:23346727,“background”:4450433},“tracks”:{“all”:43884,“single_message”:9449},“messages”:413452609}
This doesn’t mean a great deal to me I’m afraid
